1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Support module for PV pre-defined values
From: "Pueyos, Armando \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: Ulrik Pedersen <[email protected]>
Date: Thu, 4 May 2023 12:52:56 +0000
Hi Ulrik,
Yeah, you guessed it. My idea is to implement it as a Python softioc, with more parameters and more flexibility. Just asked here in order to avoid re-inventing the wheel.
Cheers,
    Armando
Sent: 04 May 2023 12:37
To: Pueyos, Armando (DLSLtd,RAL,LSCI) <[email protected]>
Cc: [email protected] <[email protected]>
Hi Armando,
I'm afraid I haven't got a ready-baked solution for this one. However, I have always thought the DLS "positioner" could be implemented quite neatly as a state machine in SNL...?
As an alternative (and arguably more "modern" feel) how about a python softioc? https://github.com/dls-controls/pythonSoftIOC
Cheers,
Ulrik
On Thu, 4 May 2023 at 11:47, Pueyos, Armando (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]> wrote:
Hello all,
I am trying to find some support module that would allow to store some values and apply these to at least 1 PV from an enum. The idea is to allow end users to defining pre-selected values and apply these to a configured PV or group of PVs on demand. Ideally, something independent of the motor record that can be applied to any existing PV.
As an example, let's imagine a motor-controlled multi-filter with specific positions for each one (e.g. Cu=0, Si=50, Pt=80): the user can drive it to any value within range using a motor record, but also can comfortably select one the positions and command the motion to any of the specific values -- in the example, when selecting "Pt" the motor is commanded to value=80.
FYI, at Diamond we do have a similar one called simply "positioner", but it's quite complex and old for proper maintainability, and thus I am looking for a substitute.
Does anyone know about or have already implemented EPICS support for something like that? Please let me know, any help would be much appreciated.
Many thanks,
    Armando Pueyos
Support module for PV pre-defined values Pueyos, Armando (DLSLtd, RAL, LSCI) via Tech-talk
Re: Support module for PV pre-defined values Ulrik Pedersen via Tech-talk
Prev: Re: Support module for PV pre-defined values Mark Rivers via Tech-talk
Next: Re: Support module for PV pre-defined values Pueyos, Armando (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Support module for PV pre-defined values Ulrik Pedersen via Tech-talk
Next: Re: Support module for PV pre-defined values Mark Rivers via Tech-talk
