1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor
To: Alexander Kessler <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 May 2023 19:25:50 +0000
Did you disable the Windows firewall, or put the CA exceptions in it?
You should be able to remove the :5065 from your EPICS_CA_ADDR_LIST.
From: Tech-talk <[email protected]> On Behalf Of Alexander Kessler via Tech-talk
Sent: Monday, May 8, 2023 2:20 PM
To: [email protected]
Subject: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor
Dear Community,
I am new to EPICS and need some  start up help.
I have compiled EPICS 7.0.4.1 following these instructions:
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows-msys2.html
under Windows 10 MSYS2 MinGW.
After that I have build the test application. I work in the MSYS2 shell. When I start the TestIOC I get the following output:
$ ../../bin/windows-x64-mingw/test st.cmd
#!../../bin/windows-x64-mingw/test
< envPaths
epicsEnvSet("IOC","ioctest")
epicsEnvSet("TOP","C:/Users/AlexK/work/epics/testioc")
cd "C:/Users/AlexK/work/epics/testioc"
dbLoadDatabase "dbd/test.dbd"
test_registerRecordDeviceDriver pdbbase
Warning: IOC is booting with TOP = "C:/Users/AlexK/work/epics/testioc"
          but was built with TOP = "/c/Users/AlexK/work/epics/testioc"
## Load record instances
dbLoadRecords("db/test.db","user=AlexK")
cd "C:/Users/AlexK/work/epics/testioc/iocBoot/ioctest"
iocInit
Starting iocInit
## EPICS R7.0.4.1
## Rev. 2023-05-03T15:03+0200
Warning: Duplicate EPICS CA Address list entry "192.168.56.255:5065" discarded
## Start any sequence programs
#seq sncxxx,"user=AlexK"
epics>
epics> dbl
test:add
test:pv1
test:pv2
So far so good. When I clone the shell session with mintty & and start camonitor, I get:
$ camonitor.exe test:add
test:add                       *** Not connected (PV not found)
CAC: Unable to connect because "WINSOCK Error 10051"
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "0.0.0.1:5"
    Source File: ../cac.cpp line 1237
    Current Time: Mon May 08 2023 20:59:00.391220265
So I wanted to get rid of the warnings about duplicate addresses. I have tried to set the environment variables EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST in various ways. Among others, in the testioc\iocBoot\ioctest\envPaths with epicsEnvSet() , and in the shell with export and setx commands. But no matter what I do, the behaviour does not change.
My dev PC has two ethernet cards. The second one has multiple IP4 addresses for communication with lab network and local test equipment.
Windows-IP-Konfiguration
Ethernet-Adapter Ethernet 3:
   IPv4-Adresse  . . . . . . . . . . : my uni net IP 4
   Subnetzmaske  . . . . . . . . . . : the subnet mask
Ethernet-Adapter Ethernet 2:
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : National Instruments GigE Vision Adapter
   Physische Adresse . . . . . . . . : 00-1B-21-3A-27-43
   DHCP aktiviert. . . . . . . . . . : Nein
   Autokonfiguration aktiviert . . . : Ja
   Verbindungslokale IPv6-Adresse  . : fe80::7ebe:1e43:828e:2e48%10(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.2.222(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   IPv4-Adresse  . . . . . . . . . . : 192.168.11.222(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.50.222(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.55.222(Bevorzugt)
   Standardgateway . . . . . . . . . : 192.168.50.3
   DHCPv6-IAID . . . . . . . . . . . : 124257738
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-26-CF-F0-B5-18-66-DA-08-54-53
   DNS-Server  . . . . . . . . . . . : 192.168.50.3
   NetBIOS über TCP/IP . . . . . . . : Aktiviert
Ethernet-Adapter Ethernet 4:
   Beschreibung. . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
   Physische Adresse . . . . . . . . : 0A-00-27-00-00-07
   Verbindungslokale IPv6-Adresse  . : fe80::5129:dd7d:57d7:4fe0%7(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.56.100(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 470417447
   DNS-Server  . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter VirtualBox Host-Only Network #2:
   Beschreibung. . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter #2
   Physische Adresse . . . . . . . . : 0A-00-27-00-00-09
   Verbindungslokale IPv6-Adresse  . : fe80::7e21:9f3a:57ab:49c7%9(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.56.2(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 537526311
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
The set of EPICS env. variables looks like this:
$ printenv | grep EPICS
EPICS_CA_ADDR_LIST=192.168.50.222:5065
EPICS_HOST_ARCH=windows-x64-mingw
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_BASE=C:\Users\AlexK\work\epics\base-R7.0.4.1
 I think I am close to the target, but somewhere I have a thinking error. I assume this is related to the handling of the environment variables in MSYS2 Shell and EPICS.
Best wishes and thank for reading this long e-mail :-)
AlexK
Alexander Kessler
Helmholtz-Institut-Jena
Fröbelstieg 3, 07743 Jena
phone:    +49-3641-947296
fax:      +49-3641-947299
email:    [email protected]
web:      http://www.rlp-ioq.uni-jena.de/
          http://www.hi-jena.de
Facility for Antiproton and Ion Research in Europe GmbH (FAIR GmbH) GSI Helmholtzzentrum für Schwerionenforschung GmbH Planckstraße 1, 64291 Darmstadt, Germany, www.fair-center.eu, www.gsi.de
Commercial Register / Handelsregister:
FAIR: Amtsgericht Darmstadt, HRB 89372
GSI: Amtsgericht Darmstadt, HRB 1528
Managing Directors / Geschäftsführung:
Professor Dr. Paolo Giubellino, Jörg Blaurock Chairman of the GSI Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
Ministerialdirigent Dr. Volkmar Dietz
Re: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor Alexander Kessler via Tech-talk
Prev: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor Alexander Kessler via Tech-talk
Next: Re: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor Alexander Kessler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
