1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 9 May 2023 09:45:16 +0200
Trying to give a bit more details...
On Mon, 8 May 2023 at 21:21, Alexander Kessler via Tech-talk <[email protected]> wrote:
I have compiled EPICS 7.0.4.1 following these instructions:
https://docs.epics-controls.org/projects/how-tos/en/latest/getting-started/installation-windows-msys2.html
under Windows 10 MSYS2 MinGW.
That all looks good.
My dev PC has two ethernet cards. The second one has multiple IP4 addresses for communication with lab network and local test equipment.
That's what is causing your issues.
By default, the CA client broadcasts the channel name resolution requests on all network interfaces found. If the IOC is hosted on a machine that is part of multiple of those networks, it will get multiple name requests and send back multiple answers, which the client detects and doesn't like.
The set of EPICS env. variables looks like this:
$ printenv | grep EPICS
EPICS_CA_ADDR_LIST=192.168.50.222:5065
EPICS_HOST_ARCH=windows-x64-mingw
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_BASE=C:\Users\AlexK\work\epics\base-R7.0.4.1
I think I am close to the target,
You are!
That's correct and necessary. It stops the CA client from sending broadcasts on all found networks.
Next step: Decide which network should be used for your CA connection to the IOC. I am assuming it's the 192.168.50.0/24 network.
Now, to reach all IOCs on the selected CA network, set the EPICS address list variable to its broadcast address.
The port number you are setting (5065) is *not* the default port for CA. Do this only if you also set your IOC to use a non-standard port. Assuming this was not intended, I would try using
EPICS_CA_ADDR_LIST=192.168.50.255
Hope this helps.
~Ralph
Liebe Grüße nach Jena!
EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor Alexander Kessler via Tech-talk
Prev: Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
Next: Save the date! Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: EPICS 7.0.4.1. Gettings Started under Windows 10 WSYS2 MinGW UCRT 64, Problem with camonitor Alexander Kessler via Tech-talk
Next: Increasing NDArray XSize and YSize with areaDetector Marco A. Barra Montevechi Filho via Tech-talk
