Per Kay’s suggestion I tried using channel access, and that worked. I think my problem is that I was using PVA:// and not pva:// Apparently those are case sensitive.
Thanks for all the help,
Greg
Use caution with links and attachments.
One step in debugging would be to see if that record is processing. You can set the TPRO (Trace PROcessing) field of that record to 1. Then you will see a message each time the record processes.
Set ASYN_TRACEIO_MASK on the underlying port to ESCAPE
Set the ASYN_TRACE_MASK on the underlying port to DRIVER|ERROR
You will then see messages for the actual communication to the device.
Try using caput to write to the record. Then try pvput.
Hi folks,
I've finally gotten EPICS chatting reasonably with my Keysight 34980A mainframes, both to read data through one of the MUX cards, and now to output voltages through the DAC. My next step is to start building some interfaces. Reading in and graphing some data
trends went quite well using the examples and modifying them to use PVA://myPVname. I'm having more trouble getting output sent out to my PVs.
I started with the "Incremental Controls"/spinner slider scrollbar and looked at modifying the scaled slider horizontal widget. I modified it to use PVA://KS_34980A_EPICStestwriteOutput1 and adjusted the values to go from 0 to 16 in 0.1 increments, and turned
off the hi/lo labels. However, when I try to drag the slider, it pops back to 0 immediately when I release the mouse button. Using the keyboard makes the slider move but doesn't change the PV.
I can write to that PV using 'pvput KS_34980A_EPICStestwriteOutput1 #' and see that it does indeed update, so I think I must be doing something wrong in Phoebus. I've attached my slider.bob file. The record that I'm writing to looks like:
record(ao, "$(P)$(R)writeOutput1") {
field(DESC, "Write to Test Output 1")
field(DTYP, "stream")
field(PREC, "3")
field(EGU, "Volts")
field(SCAN, "Passive")
field(OUT, "@devKS_34980A_EPICS.proto setSourceVoltage(%E,2001) $(PORT) $(A)" )
field(PINI, "YES")
field(VAL, "0")
field(FLNK, "$(P)$(R)readOutput1")
Any pointers are greatly appreciated,
Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
[email protected]
M: (401) 52-OUAL1 or (401) 526-8251
- Phoebus Slider Leblanc, Gregory via Tech-talk
- Re: Phoebus Slider Mark Rivers via Tech-talk
Re: Why does libca.so depend on libreadline.so? Mark Rivers via Tech-talk
When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
