Hi Jakub,
I would suggest using an ao record in your aggregating IOC. It should be in Closed Loop mode with a DOL field that specifies a CP link to the remote IOC. That record gets processed whenever the remote IOC value changes. That ao record
OUT link writes the value to your aggregating IOC using the asynFloat64 interface. This way you don’t need to worry about Channel Access in your driver.
Wlodek, Jakub via Tech-talk
Sent: Thursday, May 18, 2023 10:10 AM
To: [email protected]
Subject: Optimal way to offer readback of PV from one IOC as a PV within another IOC
Essentially the use case of this is that I have an IOC that aggregates some signals into a custom data structure and transmits the data live over a TCP/IP socket. Most of the signals are calculated
within this IOC itself, but there are two additional ones that I'd like to include that are currently provided by another IOC. For context, the data aggregation IOC is an asynPortDriver, and both signals should be asynFloat64 ao readbacks. What would be the
best way to do this? Camonitor/caget events within the readFloat64 method? Or some other solution?
- Optimal way to offer readback of PV from one IOC as a PV within another IOC Wlodek, Jakub via Tech-talk
Re: Question about Phoebus Kasemir, Kay via Tech-talk
RE: Optimal way to offer readback of PV from one IOC as a PV within another IOC Pearson, Matthew via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
