1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: 回复: [EXTERNAL] procServ comminication with phoebus problem
From: wang Ewen via Tech-talk <tech-talk at aps.anl.gov>
To: "Hartman, Steven" <hartmansm at ornl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 2 Jun 2023 06:00:23 +0800
Hi ,
   Thank you for your reply, it's working fine now. I want to run more than one iocs at the same times communication with css phoebus,is it the same port 5064? And just change the ioc name and port?
Is it can autorestart when the server restart?
Best regards,
Ewen
Windows 邮件发送
发件人: Hartman, Steven
发送时间: 202362 0:15
收件人: wang Ewen
抄送: tech-talk at aps.anl.gov
主题: Re: [EXTERNAL] procServ comminication with phoebus problem
On Jun 1, 2023, at 10:59 AM, wang Ewen via Tech-talk <tech-talk at aps.anl.gov> wrote:
[root@localhost iocmyexample]# procServ -n "my-ioc" -L my-ioc.log -P 8888 -i "^D^C" /usr/local/EPICS/iocs/iocBoot/iocmyexample/st.cmd
My phoebus setting.ini is::
org.phoebus.pv.ca/addr_list=192.168.238.134:8888
That is incorrect. In your configuration, procServ is using port 8888 to provide connection to the IOC console it serves. Channel Access is still using port 5064. Try org.phoebus.pv.ca/addr_list=192.168.238.134:5064.
You should be able to telnet to port 8888 to connect to the IOC shell via procServ.
Steven Hartman
RE: [EXTERNAL] procServ comminication with phoebus problem Mark Rivers via Tech-talk
procServ comminication with phoebus problem wang Ewen via Tech-talk
Re: [EXTERNAL] procServ comminication with phoebus problem Hartman, Steven via Tech-talk
Prev: Re: [EXTERNAL] procServ comminication with phoebus problem Hartman, Steven via Tech-talk
Next: 回复: [EXTERNAL] procServ comminication with phoebus problem wang Ewen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: RE: [EXTERNAL] procServ comminication with phoebus problem Mark Rivers via Tech-talk
ANJ, 02 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
