1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: interrupt read data in int32Driver example
To: [email protected]
Date: Fri, 7 Jul 2023 14:18:03 +0800
Dear community,
I would like to learn about the usage of epics interrupt. I found an example routine called `int32Driver` (asyn/iocBoot/ioctestEpics/st.cmd and asyn/testEpicsApp/src). In the `st.cmd` script, there is a record instance that I want to use to run an interrupt because it has `SCAN=I/O Intr`. Here is the example record instance:
record(ai,"asyndevAiInt32A0") {
    field(SCAN,"I/O Intr")
    field(DTYP,"asynInt32")
    field(INP,"@asyn( int32 , 0 , 1.0) ")
    field(LINR,"LINEAR")
    field(EGUF,"100.0")
    field(EGUL,"-100.0")
    field(PREC,"3")
After running `epics` using the above command, I tried to read the data generated by the interrupt using `caget asyndevAiInt32A0`. However, the return value of `caget` did not change. How can I make `asyndevAiInt32A0` generate a read data interrupt to software simulate a hardware interrupt that produces new data?
RE: interrupt read data in int32Driver example GAGET Alexis via Tech-talk
Re: interrupt read data in int32Driver example Mark Rivers via Tech-talk
Prev: Re: Re: [EXTERNAL] Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
Next: Re: [EXTERNAL] phoebus Tank widget: Limits from PV? Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Re: Record process when restore using autosave Mark Rivers via Tech-talk
Next: RE: interrupt read data in int32Driver example GAGET Alexis via Tech-talk
