1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: changing compiler versions
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Pierrick M Hanlet <[email protected]>
Date: Fri, 7 Jul 2023 12:36:14 -0700
Do you mean "changing language standard version"?
On 7/7/23 12:12, Pierrick M Hanlet via Tech-talk wrote:
Greetings all,
I'd like to build our EPICS software (starting on an Alma Linux 9 platform) for
C++17 or even C++20.
What is motivating this?  imo. language version might best be
decided on a per-module basis.  eg. for PVXS I set -std=c++11
I haven't tried, but I would not be surprised if some of our
more... mature c++ code might not compile with c++20.
On the chance that you are thinking the -std= effects ABI,
you will want to read:
https://gcc.gnu.org/onlinedocs/libstdc++/manual/using_dual_abi.html
  I'm presently building with C++11 by adding
-std=c++11 to the USR_CXXFLAGS in  configure/CONFIG_COMMON.
USR_* is probably not the best place to put this if you want to
effect downstream builds as well.  Some module builds will
overwrite these variables instead of appending.
Looking at some places where this is already done in base might
provide a starting point.
$ git grep '\-std='
configure/os/CONFIG.Common.RTEMS-uC5282:ARCH_DEP_CXXFLAGS_5 = -std=c++98
configure/os/CONFIG.Common.solaris-sparc-gnu:POSIX_CFLAGS = -std=gnu99 -D_POSIX_C_SOURCE=200112L
configure/os/CONFIG.Common.solaris-x86-gnu:POSIX_CFLAGS = -std=gnu99 -D_POSIX_C_SOURCE=200112L
  However,
when I tried c++20/c++17/c++14 and it failed in every case with:
  * g++: error: unrecognized command line option ‘-std=c++20’
Could you share the exact command invocation which gives this error?
(also, which GCC version?)
somewhere in the middle of building libcom - after the compilation call to
resourceLib.
A colleague of mine played with the configure/CONFIG.gnuCommon and
had a different level of success and failure.
Any help, even pointing me to the correct documentation would be
greatly appreciated.
Cheers,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
changing compiler versions Pierrick M Hanlet via Tech-talk
Prev: changing compiler versions Pierrick M Hanlet via Tech-talk
Next: Re: External: changing compiler versions Niko Kivel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
