1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Real-Time Spectral Analysis of streaming data in EPICS operator screens.
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Evans, Richard K. (GRC-H000)" <[email protected]>
Date: Mon, 10 Jul 2023 09:23:50 -0700
On 6/23/23 14:23, Evans, Richard K. (GRC-H000) via Tech-talk wrote:
Hello,
What software tools/components would best enable an EPICS system to render real-time frequency plots (fft/psd) of single channels of data as it is being recorded? Is that possible within CSS/Phoebus? I can't find any mention in the CSS documentation about displaying live frequency plots).
(I somehow overlooked this post last month...)
Usual design practice with EPICS would have computationally
expensive operations like an FFT done once in an IOC instead
of repeated in every client.  The assumption being that there
will always be more than one client.
I know of, and have been responsible for, a number for drivers
include include FFT calculations.  I have found that there is
just enough variation to prevent easy generalization.  cf.
differences like complex vs. real inputs.  Windowing or other
filtering.  Log vs. linear output.  Whether to include 0Hz.
Phase "unwrapping".  etc...
As a case in point.  The FEED driver for the LBL Marble board
includes FFT calculation (added by Sonya Hoobler @SLAC).
Of course, that code was created for RF applications, and  might
need some need some adaption for yours.
Elaine Chandler's User meeting talk on April 25th, 2023 at Fermilab, titled: "C2 Data Viewer: Visualization tool for EPICS7 Data Streaming" [1] describes a DAQ "scope" application that I would like to consider using, but I was told that this capability also exists in other tools as well and I should learn about all the tools that do this before deciding how to implement this. Is this (real-time spectral display of data) a common capability? What does the community recommend? Thanks!
(Assume the underlying EPICS system is acquiring data using an FMC IOC with fast ADCs -  i.e. Marble [2] and Zest [3] at 50 kSPS)
Thanks!
/Rich
[1] https://indico.fnal.gov/event/58280/contributions/264784/
[2] https://github.com/BerkeleyLab/Marble
[3] https://github.com/BerkeleyLab/Zest
- Richard Evans, NASA GRC - Armstrong Test Facility
   Data and Information Systems Management
   Public URI: https://www.linkedin.com/in/rkevans
   Agency URI: https://wiki.grc.nasa.gov/pbgeneral/User:Rkevans
Real-Time Spectral Analysis of streaming data in EPICS operator screens. Evans, Richard K. (GRC-H000) via Tech-talk
Prev: RE: Question on Accessing Data in Custom PV Structures Srinivas, Dhruv via Tech-talk
Next: EPICS Software Supply Chain Risk Management (SSCRM) Evans, Richard K. (GRC-H000) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: [EXTERNAL] Re: Real-Time Spectral Analysis of streaming data in EPICS operator screens. Evans, Richard K. (GRC-H000) via Tech-talk
Next: Open position in Controls @ PSI - control system specialist Celcer Tine via Tech-talk
