1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: A question on modbus
To: Amber <[email protected]>, tech-talk <[email protected]>
Date: Tue, 11 Jul 2023 15:48:12 +0000
Hi Kevin,
  • There is another command to open the device, which should write " \x01 \x05 \x00 \x00 \xFF \x00  \x8C \x3A" to the device.
That is a standard Modbus command.  It uses function code 5 (write single coil) using data="" to address=0.  The value 0xff00 is what the Modbus standard requires to be written to a single coil for the bit value 1.
You need to create another driver with this command:
drvModbusAsynConfigure("V1","Init", 1,5,0,1,0,0, "Init")
You can create a template file called modbusInit.template in the same directory with your startup script.
record(bo,"$(P)$(R)") {
    field(DTYP,"asynUInt32Digital")
    field(OUT,"@asynMask($(PORT) 0 0x1)")
    field(VAL, “1”)
    field(PINI, “YES”)
That record will process during iocInit (because PINI=YES).  It will write the value 0xff00 to address 0 using function code 5.
Load that file in your startup script with the command
dbLoadRecords(modbusInit.template”, “P=power:,R=init,PORT=V1”)
From: Tech-talk <[email protected]> On Behalf Of Amber via Tech-talk
Sent: Tuesday, July 11, 2023 3:04 AM
To: tech-talk <[email protected]>
Subject: A question on modbus
Hello everyone,
I am using a device with Modbus-RTU protocol. The communication data is transmitted in hexadecimal words.
I want to use the modbus module in epics to solve this problelm.
When reading device data, the follwing sentence is used in the .cmd file:
drvModbusAsynConfigure("V1","Power", 1,3,0,1,0,1000, "Power")
and in the substitution file:
file "../../db/ai.template" { pattern
{P,         R,      PORT,               OFFSET, BITS,  EGUL,  EGUF,   PREC,   SCAN}
{power:,    V_read,   V1,   0,      16,    0.,   655.35,     2,      "I/O Intr"}
Command
01
05
00
00
FF
00
8C
3A
Address
Function code
Register address 0
Data 0
CRC
Reply
Be same with command
After reading all the examples I still don't know how to send this command with modbus module correctly. I think I didn't understand them clearly.
Would you like to give me some advice?  Is it suitable to use modbus module?  How to realize it?
Thank you very much.
with my best wishes,
Kevin
=?gb18030?b?u9i4tKO6UkU6IEEgcXVlc3Rpb24gb24gbW9kYnVz?= =?gb18030?b?QW1iZXI=?= via Tech-talk
A question on modbus Amber via Tech-talk
Prev: RE: [EXTERNAL] Re: EPICS Software Supply Chain Risk Management (SSCRM) Evans, Richard K. (GRC-H000) via Tech-talk
Next: Re: [EXTERNAL] Re: EPICS Software Supply Chain Risk Management (SSCRM) Joshua Einstein-Curtis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: A question on modbus Amber via Tech-talk
Next: =?gb18030?b?u9i4tKO6UkU6IEEgcXVlc3Rpb24gb24gbW9kYnVz?= =?gb18030?b?QW1iZXI=?= via Tech-talk
