Hi, I met teo question when using xspress of git. https://github.com/epics-modules/xspress3/tree/master/xspress3App/Db Could someone give me advice. I use ioc_1Channel st.md, OS was Rocky 9.0 *************************Error 1*************** Record "XSP3_1Chan:C1:DeadTime_RBV" does not have a field "INP" Error at or before ")" in path "/home/xspress3/epics/xspress3/db" file "xspress3ChannelDeadtime.template" line 12 Record "XSP3_1Chan:C1:DTFactor_RBV" does not have a field "INP" Error#MCAs: create StdArray for Visualization: NDStdArraysConfigure("MCA1", 5, 0, "CHAN1", 0, 0) ***** xspress3ChannelDeadtime.template ***** # percent deadtime = allevent*event width + time in reset record(ao, "$(P)C$(CHAN):DeadTime_RBV") { field(DTYP, "asynFloat64") field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))XSP3_CHAN_DTPERCENT") # line 12 field(VAL, "0") field(PREC, "5") } I don't know how to solve it. ****************** Error 2 ******************************* ############################################################################ ## EPICS R7.0.3.1 ## EPICS Base built Jun 26 2023 ############################################################################ reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** reboot_restore: done with file 'auto_settings.sav' XSP3_1Chan:C1:DeadTime_RBV devAsynFloat64::initCommon invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams Error (514,514) PV: XSP3_1Chan:C1:DeadTime_RBV ao: init_record XSP3_1Chan:C1:DTFactor_RBV devAsynFloat64::initCommon invalid INST_IO Must be asyn(<port> <addr> <timeout>)userParams Error (514,514) PV: XSP3_1Chan:C1:DTFactor_RBV ao: init_record reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** reboot_restore: done with file 'auto_settings.sav' Regards, Lynn
ANJ, 13 Jul 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
