1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: PHAS and PINI
Date: Tue, 18 Jul 2023 15:57:54 +0000
Folks,
Does PHAS control the order in which records with PINI=YES are processing during iocInit, even is SCAN=Passive?  The R7-0 Record Reference Documentation says this:
The PINI field specifies record processing at initialization. If it is set to YES during database configuration, the record is processed once at IOC initialization (before the normal scan tasks are started).
The PHAS field orders the records within a specific SCAN group. This is not meaningful for passive records. All records of a specified phase are processed before those with higher phase number. It is generally better practice to use linked passive records to enforce the order of processing rather than a phase number.
That seems to imply that PHAS does not apply with processing due to PINI=YES for SCAN=Passive records.  If this is not true then I suggest the documentation should be changed.
Re: PHAS and PINI Michael Davidsaver via Tech-talk
Prev: Re: Phoebus formulas Gabriel Fedel via Tech-talk
Next: IOC using Sequencer Module Attempting to use libCom.so.3.18.1 Srinivas, Dhruv via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Fermilab: Software Developer Opening in Accelerator Controls Dennis J. Nicklaus via Tech-talk
Next: Re: PHAS and PINI Michael Davidsaver via Tech-talk
