1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Phoebus Array widget with Action Button as elements
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 26 Jul 2023 12:28:02 +0000
Hi Tech-talk
I have the use case wherein I want to have Action Button as elements of Array Widget and put some actions using the element's value as pointed out by the tooltip. For ex - I can get each array value if I use say text update and the tooltip points to the corresponding element
However, When I used the Action button instead, the result is
The OPI CSS works well for the same and the result is
Is Action Button as elements works with Array Widget in Phoebus?.
Many Thanks
Sandeep
Prev: Re: few questions on autosave Michael Davidsaver via Tech-talk
Next: Access Nth element in array with CSS Phoebus. Eusebio Naif Al-Soliman Fuentes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 26 Jul 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
