1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Dante-1-1
To: "Siddons, David" <[email protected]>
Date: Sun, 13 Aug 2023 00:59:51 +0000
Hi Pete,
What firmware is your unit running?
Does the vendor software work OK?
I’ll be back from vacation on Monday.
Sent from my iPhone
On Aug 12, 2023, at 9:09 AM, Siddons, David via Tech-talk <[email protected]> wrote:
We have an 8-channel Dante system from XG labs. It has 6 detectors connected. I made a fresh synApps install on Ubuntu 22.04, epics 7.0.6 and added the dante-1-1 module to it. All built well.
Starting up the mcaDanteApp from iocDante8, I got a long string of errors ending in a dump. I have attached the st.cmd (renamed st.txt so it isn't blocked) file and the console output. I'm sure it is something stupid, but I don't know if it is even supposed to work; the doc says it hasn't been tested much and I am new to both the hardware and the code.
Any suggestions appreciated.
Pete.
<log.txt>
<st.txt>
Re: Dante-1-1 Siddons, David via Tech-talk
Fw: Dante-1-1 Siddons, David via Tech-talk
Prev: Fw: Dante-1-1 Siddons, David via Tech-talk
Next: Re: Dante-1-1 Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
