1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Is there a maximum threshold plugin for areaDetector?
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Mon, 14 Aug 2023 19:11:09 +0000
Hi all!
Im using BadPixel plugin to mask some bad pixels in our detectors. The thing is some pixels only show broken values from time to time...
Is there any plugin that would mask any pixel with a value above a certain configurable threshold value?
In a similar line of thought, I noticed the statistics plugin allows the user to configure a minimal value (centroidThreshold) below which the pixel value is not going to be considered. Is there something similar for a *maximum* value?
Thanks for any hints,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Is there a maximum threshold plugin for areaDetector? Wang Xiaoqiang via Tech-talk
Prev: Re: Dante-1-1 Siddons, David via Tech-talk
Next: Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: static libraries Andrew Johnson via Tech-talk
Next: Re: Is there a maximum threshold plugin for areaDetector? Wang Xiaoqiang via Tech-talk
