1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Storing the output of ticker in the PVXS example into a database record in an IOC
From: Joao Paulo Martins via Tech-talk <[email protected]>
Date: Tue, 15 Aug 2023 08:07:12 +0000
Hello Andy,
The simplest thing you can do to achieve this is to use PVA links in your DB:
record(longin, "$(P)$(R)DBRTicker") {
    field(DESC, "Copy of PVXS ticker")
    field(INP,  {pva:{pv:"$(P)$(R)PVXSTicker",proc:true}})
Kind regards,
/João Paulo
From: Tech-talk <[email protected]> on behalf of Wang, Andrew via Tech-talk <[email protected]>
Sent: Tuesday, August 15, 2023 6:50 AM
To: EPICS tech-talk
Subject: Storing the output of ticker in the PVXS example into a database record in an IOC
Hi all,
I am attempting to understand and explore some PVAccess and thought that PVXS might be a good place to start. I was able to successfully build PVXS and run ticker in the example directory.
I am interested to know if it is possible for the output generated by ticker to be stored in a V3 record. A list of steps that will allow me to get started will be greatly appreciated.
Andy
Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
Prev: Re: Is there a maximum threshold plugin for areaDetector? Wang Xiaoqiang via Tech-talk
Next: Sequencer Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
Next: RE: Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
