1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Storing the output of ticker in the PVXS example into a database record in an IOC
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 15 Aug 2023 19:36:15 -0700
On 8/15/23 15:04, Wang, Andrew via Tech-talk wrote:
Hi Paulo,
I attempted to do that, but I got an error when running st.cmd. I wonder if the syntax is different for PVXS.
Support for PVA links in the new QSRV2 is still on the TODO list.
https://mdavidsaver.github.io/pvxs/ioc.html#pvaccess-links
Andy
*Sent:* Monday, August 14, 2023 9:50 PM
*To:* EPICS tech-talk <[email protected]>
*Subject:* Storing the output of ticker in the PVXS example into a database record in an IOC
Hi all,
I am attempting to understand and explore some PVAccess and thought that PVXS might be a good place to start. I was able to successfully build PVXS and run ticker in the example directory.
I am interested to know if it is possible for the output generated by ticker to be stored in a V3 record. A list of steps that will allow me to get started will be greatly appreciated.
Andy
Purple ribbon awareness <https://www.disabled-world.com/disability/awareness/ribbons.php#purple>
Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
RE: Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
Prev: RE: Storing the output of ticker in the PVXS example into a database record in an IOC Wang, Andrew via Tech-talk
Next: Re: Is there a maximum threshold plugin for areaDetector? Wang Xiaoqiang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Sequencer Ben Franksen via Tech-talk
