1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Problem writing enum entries from asyn driver (areaDetector) ino a databse record.
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 18 Aug 2023 14:47:06 +0200
Hello,
I have a strange problem in a areaDetector plugin I currently writing. I want
to fill a mbbo record with the strings from an std::vector I get from a
library function. I copy the elements of the std::vestor to a pre allocated
char** array and fill values and severities arrays. In my writeInt32 function
I do a call to
doCallbacksEnum(strings, values, severities, nEntries, function, 0)
This leads to a crash with SIGSEGV. After recompiling my code and the asyn
module with debug symbols I managed to track down the problem to an
uninitialized variable in asynManager:
#0  0x00007ffff7f33417 in interruptStart (pasynPvt=0x0, plist=0x7fffc37f9568)
    at ../../asyn/asynDriver/asynManager.c:2438
2438        port *pport = pinterruptBase->pport;
looking at pinterruptBase it returns 0x0.
The backtrace leading to this crash is:
#1  0x00007ffff7f56b57 in asynPortDriver::doCallbacksEnum(char**, int*, int*,
unsigned long, int, int)
    (this=0x745a90, strings=0x73f4b0, values=0x744000, severities=0x744060,
nElements=7, reason=80, address=0)
    at ../../asyn/asynPortDriver/asynPortDriver.cpp:3363
#2  0x00007ffff7df1e4b in NDFileOpenPMD::writeInt32(asynUser*, int)
    (this=<optimized out>, pasynUser=<optimized out>, value=<optimized out>)
at ../NDFileOpenPMD.cpp:192
My driver is derived from NDFilePlugin as:
NDPluginFile(portName, queueSize, blockingCallbacks,
                 NDArrayPort, NDArrayAddr, 1,
                 0, 0, asynGenericPointerMask | asynEnumMask,
                 ASYN_CANBLOCK, 1, priority, stackSize, 1, true)
So in my understanding it should be configured to be able to use enum
functions.
Can anybody help me to figure out what I'm doing wrong?  I did a crosscheck
with other areaDetector plugin drivers if there is a special setting missing
and also looked at the examples from asy, but could not figur out whjat is
wrong in my code.
Jörn Dreyer
Re: Problem writing enum entries from asyn driver (areaDetector) ino a databse record. Mark Rivers via Tech-talk
Prev: Re: Dante Siddons, David via Tech-talk
Next: Re: Problem writing enum entries from asyn driver (areaDetector) ino a databse record. Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Dante Mark Rivers via Tech-talk
