1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: sscan build error
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
To: "Tech Talk ([email protected])" <[email protected]>, Vishnu Patel <[email protected]>
Date: Tue, 29 Aug 2023 06:48:34 +0000
Hi Vishnu
Do you have any specific reason for using sscan 2-10-1? If not, try using the latest version, if that helps.
Thanks
Sandeep Malu
From: Tech-talk <[email protected]> on behalf of Vishnu Patel via Tech-talk <[email protected]>
Sent: 29 August 2023 11:24
To: Tech Talk ([email protected]) <[email protected]>
Subject: sscan build error
   I have an error compiling sscan-2-10-1 with epics base 7.0.7.   I am not able to understand how to resolve it.
../scanparmRecord.c:109:1: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
  109 | epicsExportAddress(rset, scanparmRSET);
In file included from ../../../../../base-7.0.7/include/dbBase.h:22,
                 from ../../../../../base-7.0.7/include/dbAccess.h:20,
                 from ../scanparmRecord.c:54:
../../../../../base-7.0.7/include/recSup.h:68:8: note: declared here
   68 | struct rset {   /* record support entry table */
../scanparmRecord.c: In function ‘process’:
../scanparmRecord.c:141:23: warning: unused variable ‘dbAddr’ [-Wunused-variable]
  141 |         struct dbAddr dbAddr;
../scanparmRecord.c:140:13: warning: unused variable ‘i’ [-Wunused-variable]
  140 |         int i;
../scanparmRecord.c:139:24: warning: unused variable ‘isRemote’ [-Wunused-variable]
  139 |         long status=0, isRemote=0;
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I../../../..//seq-2.2.5/include -I../../../../../base-7.0.7/include/compiler/gcc -I../../../../../base-7.0.7/include/os/Linux -I../../../../../base-7.0.7/include        -c ../recDynLink.c
../recDynLink.c:46:15: error: expected ‘;’ before ‘long’
   46 | epicsShareFunc long epicsShareAPI dbNameToAddr(const char *pname,struct dbAddr *);
../recDynLink.c:46:35: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘dbNameToAddr’
../recDynLink.c: In function ‘recDynLinkAddInput’:
../recDynLink.c:200:35: error: implicit declaration of function ‘dbNameToAddr’ [-Werror=implicit-function-declaration]
  200 |         if (options&rdlDBONLY  && dbNameToAddr(pvname,&dbaddr)) return(-1);
cc1: some warnings being treated as errors
make[3]: *** [../../../../../base-7.0.7/configure/RULES_BUILD:259: recDynLink.o] Error 1
make[3]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp/src/O.linux-x86_64'
make[2]: *** [../../../../base-7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp/src'
make[1]: *** [../../../base-7.0.7/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/opt/epics/support/sscan-2-10-1/sscanApp'
make: *** [../../base-7.0.7/configure/RULES_DIRS:85: sscanApp.install] Error 2
Thank you
Vishnu
Re: sscan build error Vishnu Patel via Tech-talk
Prev: sscan build error Vishnu Patel via Tech-talk
Next: Error while compiling asyn Neidherr, Dennis Dr. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: sscan build error Vishnu Patel via Tech-talk
