1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Question about text update widget is not updating text problem for phoebus
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: neu lzf <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 11 Sep 2023 12:44:03 +0000
See https://github.com/ControlSystemStudio/phoebus/wiki/Display-Builder-Compatibility#text-update:
“Some BOY displays misused Text Update widgets as labels by leaving the pv_name empty and instead directly configuring the text.”
If you want to display the value of a PV, use a text update widget and configure it’s PV name.
If you have a number but want to display that as a label, add suitable mbbi records to the IOC to convert the states into lables, and then you’re back to simply displaying that PV in a text update widget.
From: Tech-talk <[email protected]> on behalf of neu lzf via Tech-talk <[email protected]>
Date: Monday, September 11, 2023 at 8:36 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Question about text update widget is not updating text problem for phoebus
Hi all,
I use binary SNS version of Phoebus and have two questions to consult you:
1)  ​I want to display "OK" text in Text Update Widget according to pv1 value if it is not equal to zero. I write embedded python script for phoebus as follows:
# Embedded python Script
from org.csstudio.opibuilder.scriptUtil import PVUtil
pv0=PVUtil.getDouble(pvs[0])
pv1=PVUtil.getDouble(pvs[1])
if (pv1!=0):
     widget.setPropertyValue("text","OK")
else:
  widget.setPropertyValue("text",str(format(pv0,".3f")))
the above script works well for CSS, while for phoebus it doesn't update text content to "OK" if pv1 is not equal to zero.  I have no idea what the problem of the script is.
2)  The script for phoebus doesn't show any error message if there is a syntax error in it, I wonder if I miss configuration to turn this function on and where to turn this function on.
Any help will be appreciated and thank you very much in advance.
Re: Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
Prev: Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
Next: RE: PyDevice device module compile error with linux-arm Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
