1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: PyDevice device module compile error with linux-arm
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: "Pearson, Matthew" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 12 Sep 2023 03:10:54 +0000
Hi Matt,
Yes, there are no compile errors after commenting on these two lines.
My test target CPU is 32-bit.
Thank you,
Kiman
Sent: Monday, September 11, 2023 11:02 AM
To: Ha, Kiman <[email protected]>; [email protected]
I don’t have a Ubuntu system to check, but according to this:
https://manpages.ubuntu.com/manpages/focal/en/man3/uint64_t.3avr.html
int64_t is ‘long long’
And in pywrapper.cpp:
template bool PyWrapper::exec(const std::string&, bool, char*);
template bool PyWrapper::exec(const std::string&, bool, int8_t*);
template bool PyWrapper::exec(const std::string&, bool, uint8_t*);
template bool PyWrapper::exec(const std::string&, bool, int16_t*);
template bool PyWrapper::exec(const std::string&, bool, uint16_t*);
template bool PyWrapper::exec(const std::string&, bool, int32_t*);
template bool PyWrapper::exec(const std::string&, bool, uint32_t*);
template bool PyWrapper::exec(const std::string&, bool, int64_t*);
template bool PyWrapper::exec(const std::string&, bool, uint64_t*);
template bool PyWrapper::exec(const std::string&, bool, float*);
template bool PyWrapper::exec(const std::string&, bool, double*);
// These are needed on 64-bit GNU system that defines int64_t as long instead of long long
// Unfortunately this makes the code here not very portable.
template bool PyWrapper::exec(const std::string&, bool, long long*);
template bool PyWrapper::exec(const std::string&, bool, unsigned long long*);
So the additional instantiations of ‘long long’ and ‘unsigned long long’ is causing the problem. You could try commenting those last two lines out, and see if that works, since the int64 lines have already been defined.
On my RHEL system, int64 is ‘long int’ (aka ‘long’), so it compiles fine.
I’m not really a pydevice developer, so I’m not sure of the most portable way forward here, but perhaps we can use the epics typedefs rather than the C/C++ typedefs?
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of Ha, Kiman via Tech-talk
Sent: Thursday, September 7, 2023 2:54 PM
To: [email protected]
Subject: [EXTERNAL] PyDevice device module compile error with linux-arm
I am attempting to compile the Klemen’s PyDevice device support and getting compile errors.
Any suggestions?
Host: Linux-arm
Base 7.0.7
gcc version 11.2.0 (Ubuntu 11.2.0-19ubuntu1)
$ python3-config --ldflags --embed | sed 's/-[^l][^ ]*//g' | sed 's/-l//g'
  python3.10 crypt dl  m m
Kiman
PyDevice device module compile error with linux-arm Ha, Kiman via Tech-talk
RE: PyDevice device module compile error with linux-arm Pearson, Matthew via Tech-talk
Prev: Re: Question about text update widget is not updating text problem for phoebus neu lzf via Tech-talk
Next: Re: PyDevice device module compile error with linux-arm Josh Fiddler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: PyDevice device module compile error with linux-arm Pearson, Matthew via Tech-talk
