I'm trying to get a FLIR/Point grey Grasshopper 3 working in ADSpinnaker. For the most part it is working. I can start the IOC. It connects to the camera. I can set exposure time, change auto exposure on and off, even access all the features in the camera specific features adl screens. The problem is if you actually press acquire I get a segmentation Fault. Running : Ubuntu 22.04 Latest assemble synApps script Change withPva = NO and Areadetector to R3-12-1 Otherwise compiled just fine for the most part Extracted the Camera xml using aravis. Got the template file and generated db and adl. There are a couple errors with parameter values being undefined when the IOC starts and I have a traceback from gdb. I'll paste the backtrace first as it is shorter. Then the IOC boot. Any ideas on what I am doing wrong would be greatly appreciated! traceback gdb Thread 9 "FLIR10x" received signal SIGSEGV, Segmentation fault. [Switching to Thread 0x7ffff17e8640 (LWP 1438)] ___pthread_mutex_lock (mutex=0x0) at ./nptl/pthread_mutex_lock.c:80 80 ./nptl/pthread_mutex_lock.c: No such file or directory. (gdb) backtrace #0 ___pthread_mutex_lock (mutex=0x0) at ./nptl/pthread_mutex_lock.c:80 #1 0x00007ffff7baf9ed in epicsEventTrigger () from /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9 #2 0x00007ffff7ba80dd in epicsEventMustTrigger () from /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9 #3 0x00007ffff7fb1327 in ADSpinnaker::startCapture() () from /opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/lib/linux-x86_64/libADSpinnaker.so #4 0x00007ffff79283c5 in ADGenICam::writeInt32(asynUser*, int) () from /opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam/lib/linux-x86_64/libADGenICam.so #5 0x00007ffff7dc0c71 in writeInt32 () from /opt/epics/synApps/support/asyn-R4-44-2/lib/linux-x86_64/libasyn.so #6 0x00007ffff7dd5f49 in processCallbackOutput () from /opt/epics/synApps/support/asyn-R4-44-2/lib/linux-x86_64/libasyn.so #7 0x00007ffff7da07dc in portThread () from /opt/epics/synApps/support/asyn-R4-44-2/lib/linux-x86_64/libasyn.so #8 0x00007ffff7bacfd4 in start_routine () from /opt/epics/base-3.15.9/lib/linux-x86_64/libCom.so.3.15.9 #9 0x00007ffff79c6b43 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442 #10 0x00007ffff7a57bb4 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:100 (gdb) Wed Sep 13 18:15:56 PDT 2023 IOC Boot root@mfg-02:/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spi nnakerIOC/iocBoot/iocSpinnaker# ../../bin/linux-x86_64/spinnakerApp st.cmd < envPaths epicsEnvSet("IOC","iocSpinnaker") epicsEnvSet("TOP","/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC") epicsEnvSet("ADSPINNAKER","/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC/../..") epicsEnvSet("SUPPORT","/opt/epics/synApps/support") epicsEnvSet("ASYN","/opt/epics/synApps/support/asyn-R4-44-2") epicsEnvSet("AREA_DETECTOR","/opt/epics/synApps/support/areaDetector-R3-12-1") epicsEnvSet("ADSUPPORT","/opt/epics/synApps/support/areaDetector-R3-12-1/ADSupport") epicsEnvSet("ADCORE","/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore") epicsEnvSet("AUTOSAVE","/opt/epics/synApps/support/autosave-master") epicsEnvSet("BUSY","/opt/epics/synApps/support/busy-R1-7-4") epicsEnvSet("CALC","/opt/epics/synApps/support/calc-R3-7-5") epicsEnvSet("SNCSEQ","/opt/epics/synApps/support/sequencer-mirror-R2-2-9") epicsEnvSet("SSCAN","/opt/epics/synApps/support/sscan-master") epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps/support/iocStats-master") epicsEnvSet("EPICS_BASE","/opt/epics/base") epicsEnvSet("ADGENICAM","/opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam") errlogInit(20000) dbLoadDatabase("/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC/dbd/spinnakerApp.dbd") spinnakerApp_registerRecordDeviceDriver(pdbbase) # Use this line for a specific camera by serial number, in this case a BlackFly GigE epicsEnvSet("CAMERA_ID", "22246598") #epicsEnvSet("CAMERA_ID", "0") epicsEnvSet("GENICAM_DB_FILE", "/opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam/db/Grasshopper3_GS3_U3_41C6NIR.template") < st.cmd.base # Prefix for all records epicsEnvSet("PREFIX", "FLIR10x:") # The port name for the detector epicsEnvSet("PORT", "FLIR10x") # Really large queue so we can stream to disk at full camera speed epicsEnvSet("QSIZE", "2000") # The maximim image width; used for row profiles in the NDPluginStats plugin epicsEnvSet("XSIZE", "2048") # The maximim image height; used for column profiles in the NDPluginStats plugin epicsEnvSet("YSIZE", "2048") # The maximum number of time series points in the NDPluginStats plugin epicsEnvSet("NCHANS", "2048") # The maximum number of frames buffered in the NDPluginCircularBuff plugin epicsEnvSet("CBUFFS", "500") # The search path for database files # This is for Windows #epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db;$(ADGENICAM)/db;$(ADSPINNAKER)/db") # This is for Linux epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db:/opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam/db:/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC/../../db") # Define NELEMENTS to be enough for a 2048x2048x1 (mono) image epicsEnvSet("NELEMENTS", "4194304") # ADSpinnakerConfig(const char *portName, const char *cameraId, int numSPBuffers, # size_t maxMemory, int priority, int stackSize) ADSpinnakerConfig("FLIR10x", 22246598) 2023/09/14 01:27:04.906 ADSpinnaker::connectCamera exception Spinnaker: GenICam::OutOfRangeException= Value = 100 must be equal or smaller than Max = 1. : OutOfRangeException thrown in node 'StreamBufferCountManual' while calling 'StreamBufferCountManual.SetValue()' (file 'IntegerT.h', line 79) [-2002] 2023/09/14 01:27:04.906 ADSpinnaker:ADSpinnaker: camera connection failed (3) Number of cameras detected: 1 Camera 0 Device Vendor Name (DeviceVendorName):Point Grey Research Device Model Name (DeviceModelName):Grasshopper3 GS3-U3-41C6NIR Device Serial Number (DeviceSerialNumber):22246598 Device Version (DeviceVersion):FW:v2.23.3.02 FPGA:v2.02 Device Type (DeviceType):USB3Vision Report for camera in use: Feature list Port: FLIR10x Timestamp: <undefined> Input EOS[0]: Output EOS[0]: Parameter list 0 Number of parameters is: 103 Parameter 0 type=string, name=PORT_NAME_SELF, value=FLIR10x, status=0 Parameter 1 type=string, name=ADCORE_VERSION, value=3.12.1, status=0 Parameter 2 type=string, name=DRIVER_VERSION, value=3.12.1, status=0 Parameter 3 type=string, name=MANUFACTURER, value is undefined Parameter 4 type=string, name=MODEL, value is undefined Parameter 5 type=string, name=SERIAL_NUMBER, value is undefined Parameter 6 type=string, name=SDK_VERSION, value is undefined Parameter 7 type=string, name=FIRMWARE_VERSION, value is undefined Parameter 8 type=asynInt32, name=ACQUIRE, value=0, status=0 Parameter 9 type=asynInt32, name=ACQUIRE_BUSY, value=0, status=0 Parameter 10 type=asynInt32, name=WAIT_FOR_PLUGINS, value is undefined Parameter 11 type=asynInt32, name=ARRAY_SIZE_X, value=0, status=0 Parameter 12 type=asynInt32, name=ARRAY_SIZE_Y, value=0, status=0 Parameter 13 type=asynInt32, name=ARRAY_SIZE_Z, value=0, status=0 Parameter 14 type=asynInt32, name=ARRAY_SIZE, value=0, status=0 Parameter 15 type=asynInt32, name=ARRAY_NDIMENSIONS, value=0, status=0 Parameter 16 type=asynInt32, name=ARRAY_DIMENSIONS, value is undefined Parameter 17 type=asynInt32, name=DATA_TYPE, value=1, status=0 Parameter 18 type=asynInt32, name=COLOR_MODE, value=0, status=0 Parameter 19 type=asynInt32, name=UNIQUE_ID, value=0, status=0 Parameter 20 type=asynFloat64, name=TIME_STAMP, value=0, status=0 Parameter 21 type=asynInt32, name=EPICS_TS_SEC, value=0, status=0 Parameter 22 type=asynInt32, name=EPICS_TS_NSEC, value=0, status=0 Parameter 23 type=asynInt32, name=BAYER_PATTERN, value=0, status=0 Parameter 24 type=string, name=CODEC, value is undefined Parameter 25 type=asynInt32, name=COMPRESSED_SIZE, value is undefined Parameter 26 type=asynInt32, name=ARRAY_COUNTER, value=0, status=0 Parameter 27 type=string, name=FILE_PATH, value=, status=0 Parameter 28 type=asynInt32, name=FILE_PATH_EXISTS, value is undefined Parameter 29 type=string, name=FILE_NAME, value=, status=0 Parameter 30 type=asynInt32, name=FILE_NUMBER, value=0, status=0 Parameter 31 type=string, name=FILE_TEMPLATE, value=%s%s_%3.3d.dat, status=0 Parameter 32 type=asynInt32, name=AUTO_INCREMENT, value=0, status=0 Parameter 33 type=string, name=FULL_FILE_NAME, value is undefined Parameter 34 type=asynInt32, name=FILE_FORMAT, value is undefined Parameter 35 type=asynInt32, name=AUTO_SAVE, value is undefined Parameter 36 type=asynInt32, name=WRITE_FILE, value=0, status=0 Parameter 37 type=asynInt32, name=READ_FILE, value=0, status=0 Parameter 38 type=asynInt32, name=WRITE_MODE, value is undefined Parameter 39 type=asynInt32, name=WRITE_STATUS, value=0, status=0 Parameter 40 type=string, name=WRITE_MESSAGE, value=, status=0 Parameter 41 type=asynInt32, name=NUM_CAPTURE, value is undefined Parameter 42 type=asynInt32, name=NUM_CAPTURED, value=0, status=0 Parameter 43 type=asynInt32, name=CAPTURE, value=0, status=0 Parameter 44 type=asynInt32, name=DELETE_DRIVER_FILE, value is undefined Parameter 45 type=asynInt32, name=FILE_LAZY_OPEN, value is undefined Parameter 46 type=asynInt32, name=CREATE_DIR, value=0, status=0 Parameter 47 type=string, name=FILE_TEMP_SUFFIX, value=, status=0 Parameter 48 type=string, name=ND_ATTRIBUTES_FILE, value=, status=0 Parameter 49 type=asynInt32, name=ND_ATTRIBUTES_STATUS, value=1, status=0 Parameter 50 type=string, name=ND_ATTRIBUTES_MACROS, value=, status=0 Parameter 51 is undefined, name=ARRAY_DATA Parameter 52 type=asynInt32, name=ARRAY_CALLBACKS, value is undefined Parameter 53 type=asynInt32, name=POOL_MAX_BUFFERS, value is undefined Parameter 54 type=asynInt32, name=POOL_ALLOC_BUFFERS, value=0, status=0 Parameter 55 type=asynInt32, name=POOL_FREE_BUFFERS, value=0, status=0 Parameter 56 type=asynFloat64, name=POOL_MAX_MEMORY, value=0, status=0 Parameter 57 type=asynFloat64, name=POOL_USED_MEMORY, value=0, status=0 Parameter 58 type=asynInt32, name=POOL_EMPTY_FREELIST, value is undefined Parameter 59 type=asynInt32, name=NUM_QUEUED_ARRAYS, value=0, status=0 Parameter 60 type=asynFloat64, name=GAIN, value is undefined Parameter 61 type=asynInt32, name=BIN_X, value is undefined Parameter 62 type=asynInt32, name=BIN_Y, value is undefined Parameter 63 type=asynInt32, name=MIN_X, value=0, status=0 Parameter 64 type=asynInt32, name=MIN_Y, value=0, status=0 Parameter 65 type=asynInt32, name=SIZE_X, value is undefined Parameter 66 type=asynInt32, name=SIZE_Y, value is undefined Parameter 67 type=asynInt32, name=MAX_SIZE_X, value=1, status=0 Parameter 68 type=asynInt32, name=MAX_SIZE_Y, value=1, status=0 Parameter 69 type=asynInt32, name=REVERSE_X, value is undefined Parameter 70 type=asynInt32, name=REVERSE_Y, value is undefined Parameter 71 type=asynInt32, name=FRAME_TYPE, value is undefined Parameter 72 type=asynInt32, name=IMAGE_MODE, value is undefined Parameter 73 type=asynInt32, name=NEXPOSURES, value is undefined Parameter 74 type=asynInt32, name=NEXPOSURES_COUNTER, value=0, status=0 Parameter 75 type=asynInt32, name=NIMAGES, value is undefined Parameter 76 type=asynInt32, name=NIMAGES_COUNTER, value=0, status=0 Parameter 77 type=asynFloat64, name=ACQ_TIME, value is undefined Parameter 78 type=asynFloat64, name=ACQ_PERIOD, value is undefined Parameter 79 type=asynFloat64, name=TIME_REMAINING, value=0, status=0 Parameter 80 type=asynInt32, name=STATUS, value=0, status=0 Parameter 81 type=asynInt32, name=TRIGGER_MODE, value is undefined Parameter 82 type=asynInt32, name=SHUTTER_CONTROL, value is undefined Parameter 83 type=asynInt32, name=SHUTTER_CONTROL_EPICS, value is undefined Parameter 84 type=asynInt32, name=SHUTTER_STATUS, value=0, status=0 Parameter 85 type=asynInt32, name=SHUTTER_MODE, value is undefined Parameter 86 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value is undefined Parameter 87 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value is undefined Parameter 88 type=asynFloat64, name=TEMPERATURE, value is undefined Parameter 89 type=asynFloat64, name=TEMPERATURE_ACTUAL, value is undefined Parameter 90 type=asynInt32, name=READ_STATUS, value is undefined Parameter 91 type=string, name=STATUS_MESSAGE, value=, status=0 Parameter 92 type=string, name=STRING_TO_SERVER, value=<not used by driver>, status=0 Parameter 93 type=string, name=STRING_FROM_SERVER, value=<not used by driver>, status=0 Parameter 94 type=asynFloat64, name=GC_FRAMERATE, value is undefined Parameter 95 type=asynInt32, name=GC_FRAMERATE_ENABLE, value is undefined Parameter 96 type=asynInt32, name=GC_TRIGGER_SOURCE, value is undefined Parameter 97 type=asynInt32, name=GC_TRIGGER_OVERLAP, value is undefined Parameter 98 type=asynInt32, name=GC_TRIGGER_SOFTWARE, value is undefined Parameter 99 type=asynInt32, name=GC_EXPOSURE_MODE, value is undefined Parameter 100 type=asynInt32, name=GC_EXPOSURE_AUTO, value is undefined Parameter 101 type=asynInt32, name=GC_GAIN_AUTO, value is undefined Parameter 102 type=asynInt32, name=GC_PIXEL_FORMAT, value is undefined asynSetTraceIOMask(FLIR10x, 0, 2) # Set ASYN_TRACE_WARNING and ASYN_TRACE_ERROR #asynSetTraceMask($(PORT), 0, 0xff) #asynSetTraceFile($(PORT), 0, "asynTrace.out") #asynSetTraceInfoMask($(PORT), 0, 0xf) # Main database. This just loads and modifies ADBase.template dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC/../../db/spinnaker.template", "P=FLIR10x:,R=cam1:,PORT=FLIR10x") # Load the autogenerated file of GenICam features dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam/db/Grasshopper3_GS3_U3_41C6NIR.template", "P=FLIR10x:,R=cam1:,PORT=FLIR10x") # Transport diagnostics #dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=TransmitFailureCount,PN=SP_TRANSMIT_FAILURE_COUNT") #dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=BufferUnderrunCount, PN=SP_BUFFER_UNDERRUN_COUNT") #dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=FailedBufferCount, PN=SP_FAILED_BUFFER_COUNT") #dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=FailedPacketCount, PN=SP_FAILED_PACKET_COUNT") # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "FLIR10x", 0, 0) # Use this line for 8-bit data only #dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=CHAR,NELEMENTS=$(NELEMENTS)") # Use this line for 8-bit or 16-bit data dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDStdArrays.template", "P=FLIR10x:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x,TYPE=Int16,FTVL=SHORT,NELEMENTS=4194304") # Load all other plugins using commonPlugins.cmd < /opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/iocBoot/commonPlugins.cmd # This is an example file for creating plugins # It uses the following environment variable macros # Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being # use the autosave value will replace the value passed to this file. # $(PREFIX) Prefix for all records # $(PORT) The port name for the detector. In autosave. # $(QSIZE) The queue size for all plugins. In autosave. # $(XSIZE) The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT # profiles in NDPluginFFT. # $(YSIZE) The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin # $(NCHANS) The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins # $(CBUFFS) The maximum number of frames buffered in the NDPluginCircularBuff plugin # $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5. # Create a netCDF file saving plugin NDFileNetCDFConfigure("FileNetCDF1", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileNetCDF.template","P=FLIR10x:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a TIFF file saving plugin NDFileTIFFConfigure("FileTIFF1", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileTIFF.template", "P=FLIR10x:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a JPEG file saving plugin NDFileJPEGConfigure("FileJPEG1", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileJPEG.template", "P=FLIR10x:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a NeXus file saving plugin NDFileNexusConfigure("FileNexus1", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileNexus.template", "P=FLIR10x:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create an HDF5 file saving plugin NDFileHDF5Configure("FileHDF1", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileHDF5.template", "P=FLIR10x:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=FLIR10x") # Create a Magick file saving plugin #NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0) #dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Create 4 ROI plugins NDROIConfigure("ROI1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=FLIR10x:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") NDROIConfigure("ROI2", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=FLIR10x:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") NDROIConfigure("ROI3", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=FLIR10x:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") NDROIConfigure("ROI4", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=FLIR10x:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create 8 ROIStat plugins NDROIStatConfigure("ROISTAT1", 2000, 0, "FLIR10x", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDROIStat.template", "P=FLIR10x:,R=ROIStat1: ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=FLIR10x:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048") # Create a processing plugin NDProcessConfigure("PROC1", 2000, 0, "FLIR10x", 0, 0, 0) dbLoadRecords("NDProcess.template", "P=FLIR10x:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a TIFF file plugin to read dark and flatfield images into the processing plugin NDFileTIFFConfigure("PROC1TIFF", 2000, 0, "FLIR10x", 0) dbLoadRecords("NDFileTIFF.template", "P=FLIR10x:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a scatter plugin NDScatterConfigure("SCATTER1", 2000, 0, "FLIR10x", 0, 0, 0) dbLoadRecords("NDScatter.template", "P=FLIR10x:,R=Scatter1:, PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a gather plugin with 8 ports NDGatherConfigure("GATHER1", 2000, 0, 8, 0, 0) dbLoadRecords("NDGather.template", "P=FLIR10x:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDGatherN.template", "P=FLIR10x:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create 5 statistics plugins NDStatsConfigure("STATS1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=FLIR10x:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=FLIR10x") NDTimeSeriesConfigure("STATS1_TS", 2000, 0, "STATS1", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS2", 2000, 0, "ROI1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=FLIR10x:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=FLIR10x") NDTimeSeriesConfigure("STATS2_TS", 2000, 0, "STATS2", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS3", 2000, 0, "ROI2", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=FLIR10x:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=FLIR10x") NDTimeSeriesConfigure("STATS3_TS", 2000, 0, "STATS3", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS4", 2000, 0, "ROI3", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=FLIR10x:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=FLIR10x") NDTimeSeriesConfigure("STATS4_TS", 2000, 0, "STATS4", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS5", 2000, 0, "ROI4", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=FLIR10x:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2048,YSIZE=2048,NCHANS=2048,NDARRAY_PORT=FLIR10x") NDTimeSeriesConfigure("STATS5_TS", 2000, 0, "STATS5", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create a transform plugin NDTransformConfigure("TRANS1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDTransform.template", "P=FLIR10x:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create an overlay plugin with 8 overlays NDOverlayConfigure("OVER1", 2000, 0, "FLIR10x", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDOverlay.template", "P=FLIR10x:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=FLIR10x:ROI1:MinX_RBV,YPOS=FLIR10x:ROI1:MinY_RBV,XSIZE=FLIR10x:ROI1:SizeX_RBV,YSIZE=FLIR10x:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=FLIR10x:ROI2:MinX_RBV,YPOS=FLIR10x:ROI2:MinY_RBV,XSIZE=FLIR10x:ROI2:SizeX_RBV,YSIZE=FLIR10x:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=FLIR10x:ROI3:MinX_RBV,YPOS=FLIR10x:ROI3:MinY_RBV,XSIZE=FLIR10x:ROI3:SizeX_RBV,YSIZE=FLIR10x:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=FLIR10x:ROI4:MinX_RBV,YPOS=FLIR10x:ROI4:MinY_RBV,XSIZE=FLIR10x:ROI4:SizeX_RBV,YSIZE=FLIR10x:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=FLIR10x:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1") # Create 2 color conversion plugins NDColorConvertConfigure("CC1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=FLIR10x:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") NDColorConvertConfigure("CC2", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=FLIR10x:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create a circular buffer plugin NDCircularBuffConfigure("CB1", 2000, 0, "FLIR10x", 0, 500, 0) dbLoadRecords("NDCircularBuff.template", "P=FLIR10x:,R=CB1:, PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FLIR10x") # Create an NDAttribute plugin with 8 attributes NDAttrConfigure("ATTR1", 2000, 0, "FLIR10x", 0, 8, 0, 0, 0) dbLoadRecords("NDAttribute.template", "P=FLIR10x:,R=Attr1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=FLIR10x") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:2:, PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:3:, PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:4:, PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:5:, PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:6:, PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:7:, PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=FLIR10x:,R=Attr1:8:, PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048") NDTimeSeriesConfigure("ATTR1_TS", 2000, 0, "ATTR1", 1, 8) dbLoadRecords("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db/NDTimeSeries.template", "P=FLIR10x:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create an FFT plugin NDFFTConfigure("FFT1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDFFT.template", "P=FLIR10x:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=FLIR10x, NAME=FFT1, NCHANS=2048") # Create 2 Codec plugins NDCodecConfigure("CODEC1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=FLIR10x:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=FLIR10x") NDCodecConfigure("CODEC2", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=FLIR10x:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=FLIR10x") # Create a bad pixel plugin NDBadPixelConfigure("BADPIX1", 2000, 0, "FLIR10x", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDBadPixel.template", "P=FLIR10x:, R=BadPix1:, PORT=BADPIX1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=FLIR10x") set_requestfile_path("./") set_requestfile_path("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/db") set_requestfile_path("/opt/epics/synApps/support/areaDetector-R3-12-1/ADCore/iocBoot") set_requestfile_path("/opt/epics/synApps/support/autosave-master/db") set_savefile_path("./autosave") set_pass0_restoreFile("auto_settings.sav") set_pass1_restoreFile("auto_settings.sav") save_restoreSet_status_prefix("FLIR10x:") dbLoadRecords("/opt/epics/synApps/support/autosave-master/db/save_restoreStatus.db", "P=FLIR10x:") dbLoadRecords("/opt/epics/synApps/support/autosave-master/db/configMenu.db", "P=FLIR10x:, CONFIG=ADAutoSave") # Optional: load NDPluginPva plugin #NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0) #dbLoadRecords("NDPva.template", "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Must start PVA server if this is enabled #startPVAServer # Optional: load ffmpegServer plugin #ffmpegServerConfigure(8081) #ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)") #ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)") # Optional: load NDPluginEdge plugin #NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0) #dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template", "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADPLUGINEDGE)/db") # Optional: load NDPluginCV plugin #NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template", "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db") # Optional: load NDPluginBar plugin #NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template", "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADPLUGINBAR)/barApp/Db") # Optional: load scan records #dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10") #set_requestfile_path("$(SSCAN)/sscanApp/Db") # Optional: load sseq record for acquisition sequence #dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence") #set_requestfile_path("$(CALC)/calcApp/Db") # Optional: load devIocStats records (requires DEVIOCSTATS module) #dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)") # Optional: load alive record (requires ALIVE module) #dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254") # Set the callback queue size to 5000, up from default of 2000 in base. # This can be needed to avoid errors "callbackRequest: cbLow ring buffer full". callbackSetQueueSize(5000) set_requestfile_path("/opt/epics/synApps/support/areaDetector-R3-12-1/ADGenICam/GenICamApp/Db") set_requestfile_path("/opt/epics/synApps/support/areaDetector-R3-12-1/ADSpinnaker/iocs/spinnakerIOC/../../spinnakerApp/Db") iocInit() Starting iocInit ############################################################################ ## EPICS R3.15.9 ## EPICS Base built Sep 13 2023 ############################################################################ dbFindRecord for 'FLIR10x:Proc1:LowClipThresh.VAL' failed dbFindRecord for 'FLIR10x:Proc1:LowClipValue.VAL' failed dbFindRecord for 'FLIR10x:Proc1:HighClipThresh.VAL' failed dbFindRecord for 'FLIR10x:Proc1:HighClipValue.VAL' failed 2023/09/14 01:27:04.976 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_CONVERT_PIXEL_FORMAT FLIR10x:cam1:ConvertPixelFormat devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_STARTED_FRAME_COUNT FLIR10x:cam1:StartedFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_DELIVERED_FRAME_COUNT FLIR10x:cam1:DeliveredFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_RECEIVED_FRAME_COUNT FLIR10x:cam1:ReceivedFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_INCOMPLETE_FRAME_COUNT FLIR10x:cam1:IncompleteFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_LOST_FRAME_COUNT FLIR10x:cam1:LostFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_DROPPED_FRAME_COUNT FLIR10x:cam1:DroppedFrameCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_INPUT_BUFFER_COUNT FLIR10x:cam1:InputBufferCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_OUTPUT_BUFFER_COUNT FLIR10x:cam1:OutputBufferCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_RECEIVED_PACKET_COUNT FLIR10x:cam1:ReceivedPacketCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_MISSED_PACKET_COUNT FLIR10x:cam1:MissedPacketCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_RESEND_REQUESTED_PACKET_COUNT FLIR10x:cam1:ResendRequestedPacketCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:04.984 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_RESEND_RECEIVED_PACKET_COUNT FLIR10x:cam1:ResendReceivedPacketCount devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:05.005 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_TIME_STAMP_MODE FLIR10x:cam1:TimeStampMode devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:05.005 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_UNIQUE_ID_MODE FLIR10x:cam1:UniqueIdMode devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:05.009 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_CONVERT_PIXEL_FORMAT FLIR10x:cam1:ConvertPixelFormat_RBV devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:05.019 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_TIME_STAMP_MODE FLIR10x:cam1:TimeStampMode_RBV devAsynInt32::initCommon drvUserCreate 2023/09/14 01:27:05.019 asynPortDriver:drvUserCreate: addr=0, cannot find parameter SP_UNIQUE_ID_MODE FLIR10x:cam1:UniqueIdMode_RBV devAsynInt32::initCommon drvUserCreate dbFindRecord for 'FLIR10x:Proc1:LowClipThresh.VAL' failed dbFindRecord for 'FLIR10x:Proc1:LowClipValue.VAL' failed dbFindRecord for 'FLIR10x:Proc1:HighClipThresh.VAL' failed dbFindRecord for 'FLIR10x:Proc1:HighClipValue.VAL' failed iocRun: All initialization complete # save things every thirty seconds create_monitor_set("auto_settings.req", 30,"P=FLIR10x:") save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. # Wait for enum callbacks to complete epicsThreadSleep(1.0) ~Ben
ANJ, 14 Sep 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
