1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Spawn error when pyepics device puts into nonexistent PV
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Mon, 18 Sep 2023 21:14:59 +0000
I just figured the return values are None for get fail and for put fail, so that can be used for error checking.
Sorry for the inconvenience,
Marco
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: 18 September 2023 17:39
To: [email protected] <[email protected]>
Subject: Spawn error when pyepics device puts into nonexistent PV
Hi all, im using pyepics device to interact with plugins.
I tried doing:
a = epics.Device("A", delim=":",attrs=["B"])
a.put("B", 4)
Since "A:B" is a nonexistent PV in my environment, i would expect an error or at least a warning here, but i get nothing.
It seems the attribute is a PV object and PV also dont have an option for raising an exception when put to nonexistent things:
a = epics.PV("A:B")
a.put(4)
Also returns no error. Is there any way to make this happen?
Would a PR in pyepics be welcome in this direction?
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Spawn error when pyepics device puts into nonexistent PV Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: static libraries Andrew Johnson via Tech-talk
Next: IOC shell arrow keys not working. Yielding "^[[A" or "^[[Something" Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Spawn error when pyepics device puts into nonexistent PV Marco A. Barra Montevechi Filho via Tech-talk
