1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP
To: Érico Nogueira Rolim <[email protected]>
Date: Mon, 18 Sep 2023 18:26:16 +0000
It sounds like you need a record that latches the error status when there is a timeout. You could use a calcout record whose input A is the .CNCT field of the asyn record. The calcout record should be set to write its output to a bi error status record when .CNCT makes the transition from connected to disconnected.
You can manually reset the error status record as appropriate.
Sent from my iPhone
On Sep 18, 2023, at 11:49 AM, Érico Nogueira Rolim via Tech-talk <[email protected]> wrote:
Hi!
I'm using StreamDevice with a UDP device, and we have been observing some communication timeouts caused by packet drops/high CPU load (per our testing), which we only noticed due to actually opening the IOC shell and seeing multiple "No reply within 1000 ms to ..." messages. However, I'd like to be able to observe these (instantaneous) timeouts from a PV. Checking the alarm of the PVs isn't enough, because it's cleared as soon as the next communication attempt works, and having to check our archiver data for the information doesn't scale well for operation.
I instantiated the asynRecord for our port, and tried setting .DRTO to "Yes", in order to observe disconnections (which I simulated by fully disconnecting the ethernet cable from the device). The .CNCT field does go to "Disconnect", but it goes back to "Connect" for every record that is processed, and displaying the timestamp of the PV in an interface wouldn't be enough, because it is "<undefined>" (per camonitor output). Furthermore, in what seems to be a bug, once I reconnect the ethernet cable, the iocsh prints the following messages:
2023/09/18 15:30:55.702487 TIPORT DE-23RaBPM:TI-EVE:readAndUpdate: device TIPORT 0 disconnected
** reconnected cable **
2023/09/18 15:30:55.800291 TIPORT DE-23RaBPM:TI-EVE:FrmVersionA-Cte: StreamCore::lockCallback(StreamIoSuccess) called unexpectedly
and from this point on, it simply doesn't reestablish a connection. Pulling the cable again doesn't cause anything to be printed in iocsh anymore, and the records have stopped being updated (though at least they do have alarm information). I can provide more information, if necessary :)
Is there some other way of monitoring timeouts and disconnections when using asyn/StreamDevice which I'm missing?
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Érico Nogueira Rolim via Tech-talk
Prev: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Érico Nogueira Rolim via Tech-talk
Next: static libraries Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Érico Nogueira Rolim via Tech-talk
