1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: IOC shell arrow keys not working. Yielding "^[[A" or "^[[Something"
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Cc: SWC <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Sep 2023 13:19:16 +0000
Turns out its a problem with unix sockets, netcat and/or procServ!
We were running our IOCs with procServ and setting it to a unix socket. To enter the IOC shell, we did
docker exec -it myImage nc -U ./socket_file
When changing that to tcp sockets and doing telnet localhost port_number, things go just fine.
Has anyone here bumped into this before?
Sent: 18 September 2023 18:34
To: Marco A. Barra Montevechi Filho <[email protected]>
Cc: [email protected] <[email protected]>; SWC <[email protected]>
If you are using base 7.0.7 and an older Linux compiler like RHEL 7 then libreadline will not be used by default. You can update base or edit a CONFIG_SITE file in base.
Sent from my iPhone
On Sep 18, 2023, at 5:21 PM, Marco A. Barra Montevechi Filho via Tech-talk <[email protected]> wrote:
Hi all. Its been some time since in some of my IOCs the IOC shell seems to work in misterious ways with the arrow keys.
For unknown reason, most IOCs do have the functionality of using up and down arrow keys to navigate command history and left and right to navigate the line in which im writing:
but some other times, pressing up, left, down and right prints:
^[[A^[[D^[[C^[[B
But i couldnt find any major compilation difference between the applications. Am i missing something?
All my systems have libreadline-dev installed...
Thanks for any hints,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
IOC shell arrow keys not working. Yielding "^[[A" or "^[[Something" Marco A. Barra Montevechi Filho via Tech-talk
Re: IOC shell arrow keys not working. Yielding "^[[A" or "^[[Something" Mark Rivers via Tech-talk
Prev: Re: Monitor timeouts with asyn/StreamDevice, and issues in DRTO with UDP Zimoch Dirk via Tech-talk
Next: Re: Problem with CA nameserver and CA_V413 protocol Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: IOC shell arrow keys not working. Yielding "^[[A" or "^[[Something" Mark Rivers via Tech-talk
Next: Problem with CA nameserver and CA_V413 protocol Brian Bevins via Tech-talk
