1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Use sscan with transform record coordinate motion
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Wed, 20 Sep 2023 09:26:44 +0000
Hi
We want to use the sscan module to scan a coordinate motion for a slit system. The slit’s gap and center are calculated using two transform records, forward and reverse (COPT = Always). When starting a scan, if the scan’s start point is far from the current position, the scan goes quickly through the scan points and does not wait for the target set point unlike when using a motor record where the scan waits for a callback indicating the positioner is done moving. If we relatively increase the positioners’ settling time, the scan goes through all scan points.
I would like to ask, is there a way to tell the scan record from the transform record that the positioner is done moving and go to the next step of the scan?
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
[email protected]
www.sesame.org.jo
Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
Prev: Re: Streamdevice reads weird 1 byte null data Ralph Lange via Tech-talk
Next: Re: areadetector, extra IOC only for plugins Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: areadetector, extra IOC only for plugins Pete Jemian via Tech-talk
Next: Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
