1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: EPICS 7 bug with epicsStdioRedirect.h / epicsTime.h
From: "Priller, John via Tech-talk" <[email protected]>
Date: Wed, 20 Sep 2023 11:51:41 +0000
All;
My setup: Linux Debian 12 (bookworm) with gcc/g++ 12, EPICS 7.0.7.
We recently starting using EPICS 7 for our IOCs, and it's been going (mostly) smoothly so far.  But yesterday I ran into an issue where an IOC shell command in one of my c++ modules no longer properly pipes to an output file.  It creates a 0-byte file but the output just displays in the shell, it's not written to the file.
I went looking for why that was.  I lazily use "printf"s in my code, include <epicsStdioRedirect.h> at the top, and the magic has always just happened.  But in EPICS 7 it turns out that the macro redefinition of "printf" is getting stepped on by other include files.  In my case, by including <epicsTime.h> after the include of <epicsStdioRedirect.h>.
epicsTime.h includes <stdexcept>, which touches off a string of other includes until it finally includes <cstdio>, which does an #undef printf thus removing the printf redefinition made by epicsStdioRedirect.h (well, epicsStdio.h).  I found there are other header files in EPICS base 7 that include <stdexcept>, epicsTime.h was just the one that got me.
This isn't particular to gcc 12, btw, I went looking on an older IOC with gcc 10 and it has the same string of includes from stdexcept.  But it's using EPICS 3.15.9 and it's epicsTime.h doesn't include <stdexcept>, so the magic happened okay.
I have a test.cpp and a Makefile that recreate the problem, if anyone wants to play around with it.  For now I'm just including <epicsTime.h> BEFORE <epicsStdioRedirect.h> and the magic works again.  I also tried patching epicsTime.h with a kludge to re-include <epicsStdio.h> after <stdexcept> and that worked:
// KLUDGE
#ifdef epicsStdioh
  #ifndef printf
    #undef epicsStdioh
    #include <epicsStdio.h>
  #endif
#endif
But as advertised, that's a kludge.  What I should *probably* do is replace all my printf()s with epicsStdoutPrintf()s, but that's a lot of code revision, so for now I'm going with my work-around on changing order of includes.
JP
Re: EPICS 7 bug with epicsStdioRedirect.h / epicsTime.h Michael Davidsaver via Tech-talk
Prev: Re: areadetector, extra IOC only for plugins Heinz Junkes via Tech-talk
Next: Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
Next: Re: EPICS 7 bug with epicsStdioRedirect.h / epicsTime.h Michael Davidsaver via Tech-talk
