1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Starting an app from the ioc st.cmd
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>
Date: Wed, 20 Sep 2023 12:38:47 -0700
On 9/20/23 12:12, Mark Rivers via Tech-talk wrote:
Hi Pete,
I believe the “system” command is still available, but for security reasons it is disabled by default. This document:
https://epics.anl.gov/base/R3-16/2-docs/AppDevGuide.pdf <https://epics.anl.gov/base/R3-16/2-docs/AppDevGuide.pdf>
says on page 261:
Send command_string to the system command interpreter for execution. This command is present only if some application database definition file contains registrar(iocshSystemCommand) and if the system provides a suitable command interpreter (vxWorks does not).
epics-base install "system.dbd".  Add this into your IOC :)
*From:* Tech-talk <[email protected]> *On Behalf Of *Siddons, David via Tech-talk
*Sent:* Wednesday, September 20, 2023 2:05 PM
*To:* [email protected]
*Subject:* Starting an app from the ioc st.cmd
How can I make the IOC boot script also start an external program? THere used to be an iocsh command "system", but it doesn't seem to exist anymore. ALternativerly, how can I export the PV header info ($(P), $(R) ) so an external program can read  them?
I have a few systems running the same IOC with different PV headers, and I want to allow the external code to pick up the current device's headers so I don't have to manually change them.
Probably a dumb question, but I can't see how to do it 🙂
Pete.
Re: Starting an app from the ioc st.cmd Siddons, David via Tech-talk
RE: Starting an app from the ioc st.cmd Mark Rivers via Tech-talk
Prev: Re: Starting an app from the ioc st.cmd Kasemir, Kay via Tech-talk
Next: Re: Starting an app from the ioc st.cmd Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
