1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn'
To: "[email protected]" <[email protected]>, Peter Pitfield <[email protected]>
Date: Wed, 27 Sep 2023 12:55:15 +0000
Hi Peter,
The EPICS LabJack module builds an IOC application called LabJackApp.  Have you successfully built that?  You can use that IOC and the LabJack/iocBoot/iocLabJack_Txxx directory to test your device and the EPICS support.
For building your own IOC you should use the one in LackJack as an example.  Your configure/RELEASE file needs to include busy and asyn like this one:
You will probably also want to include autosave there.
Your application Makefile needs to include the _DBD and _LIBS lines for busy, asyn, and optionally autosave like this one:
From: Tech-talk <[email protected]> on behalf of Peter Pitfield via Tech-talk <[email protected]>
Sent: Tuesday, September 26, 2023 12:30 PM
To: [email protected] <[email protected]>
Subject: undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn'
Hello,
I am trying to use the labjack module, and I am receiving the error message in the subject line.
The complete error looks like this:
/usr/bin/g++ -o labjackIOC  -L/home/raphael/EPICS/IOCs/labjackIOC/lib/linux-x86_64 -L/home/raphael/EPICS/epics-base/lib/linux-x86_64 -L/home/raphael/EPICS/support/LabJack/lib/linux-x86_64 -Wl,-rpath,/home/raphael/EPICS/IOCs/labjackIOC/lib/linux-x86_64 -Wl,-rpath,/home/raphael/EPICS/epics-base/lib/linux-x86_64 -Wl,-rpath,/home/raphael/EPICS/support/LabJack/lib/linux-x86_64          -rdynamic -m64         labjackIOC_registerRecordDeviceDriver.o labjackIOCMain.o    -llabjackIOCSupport -lLabJack -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/ld: labjackIOC_registerRecordDeviceDriver.o: undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn'
/usr/bin/ld: /home/raphael/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
make[3]: *** [/home/raphael/EPICS/epics-base/configure/RULES_BUILD:231: labjackIOC] Error 1
make[3]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp/src/O.linux-x86_64'
make[2]: *** [/home/raphael/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp/src'
make[1]: *** [/home/raphael/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/home/raphael/EPICS/IOCs/labjackIOC/labjackIOCApp'
make: *** [/home/raphael/EPICS/epics-base/configure/RULES_DIRS:85: labjackIOCApp.install] Error 2
Also, I do not know how to set up an IOC with the labjack module. I have checked the readme file in the module and the documentation it has a link to, but the setup instructions did not seem complete. I would like to know what, if anything, I might be missing.
Thank you so much,
Peter
undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn' Peter Pitfield via Tech-talk
Prev: Re: undefined reference to symbol 'pvar_dset_asynInt32ArrayWfIn' Wang Xiaoqiang via Tech-talk
Next: Running area detector simulator IOC on OS X aarch64 (M2) , segmentation fault Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
