1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: Warning when building ADLightField for windows-x64 with VS2022
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
Date: Sun, 1 Oct 2023 01:07:48 +0000
Hi Mark,
I see LightField is compiled with /clr and I think this may be leading to the warning. An
epicsThreadId is defined as a pointer to a “struct epicsThreadOSD”
https://github.com/epics-base/epics-base/blob/60fa2d31da2deaaa89636b4a1f5b852efe0b2699/modules/libcom/src/osi/epicsThread.h#L108
and this is returned by  epicsThreadCreate() which is used in the lightfield code. The epicsThreadOSD structure is not defined in a public header on windows, which doesn’t normally matter as the native pointer is not meant to be dereferenced in public code, but as per https://learn.microsoft.com/en-us/cpp/error-messages/tool-errors/linker-tools-warning-lnk4248?view=msvc-170 I think the linker is unsure whether it could be a CLR type or a native type hence the warning message you see. If you changed the typedef in epicsThread.h to be:
    typedef void *epicsThreadId;
I think that may remove the warning as it has broken the link to the undefined epicsThreadOSD type
Freddie
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: 30 September 2023 22:05
To: [email protected]
Subject: Re: Warning when building ADLightField for windows-x64 with VS2022
  • LightField.obj : warning LNK4248: unresolved typeref token (01000038) for 'epicsThreadOSD'; image may not run
  • Does anyone know what causes this warning, and if it is serious?
It does not appear to be serious, because the application seems to run fine.  But I am still interested to know what might be causing that warning.
Sent: Wednesday, September 27, 2023 12:37 PM
To:
[email protected] <[email protected]>
Subject: Warning when building ADLightField for windows-x64 with VS2022
Folks,
I am getting a warning for an unresolved typeref in epicsThreadOSD when building ADLightField for windows-x64 with Visual Studio 2022 Community Edition.
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release  -MACHINE:X64      -out:LightField.dll -implib:LightField.lib     LightField.obj        J:/epics/support/areaDetector-3-12-1/ADCore/lib/windows-x64/ADBase.lib  J:/epics/support/asyn-4-44-2/lib/windows-x64/asyn.lib  J:/epics/support/areaDetector-3-12-1/ADCore/lib/windows-x64/ntndArrayConverter.lib  H:/epics/base-7.0.7/lib/windows-x64/nt.lib  H:/epics/base-7.0.7/lib/windows-x64/pvDatabase.lib  H:/epics/base-7.0.7/lib/windows-x64/pvAccess.lib  H:/epics/base-7.0.7/lib/windows-x64/pvData.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/netCDF.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/tiff.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/xml2.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/NeXus.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/hdf5.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/hdf5_hl.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/bitshuffle.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/blosc.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/szip.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/zlib.lib  J:/epics/support/areaDetector-3-12-1/ADSupport/lib/windows-x64/jpeg.lib  H:/epics/base-7.0.7/lib/windows-x64/dbRecStd.lib  H:/epics/base-7.0.7/lib/windows-x64/dbCore.lib  H:/epics/base-7.0.7/lib/windows-x64/ca.lib  H:/epics/base-7.0.7/lib/windows-x64/Com.lib gdi32.lib oleaut32.lib
   Creating library LightField.lib and object LightField.exp
Warning when building ADLightField for windows-x64 with VS2022 Mark Rivers via Tech-talk
Re: Warning when building ADLightField for windows-x64 with VS2022 Mark Rivers via Tech-talk
Prev: Re: Warning when building ADLightField for windows-x64 with VS2022 Mark Rivers via Tech-talk
Next: Tech Talk Mailing List Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Phoebus EDM autoconvert issue with a button widget Lucas Russo via Tech-talk
