Hi Ray,
This might not be what you’re looking for, but you can prevent all remote puts to any field of a record by setting its DISP field to a non-zero value. Local DB links can still write to the record and it will
still process normally, but any puts to it through CA or PVA should fail (except for puts to the DISP field, so you can undo that remotely).
You could also look at setting up Access Security which can limit when, who and from where puts will be allowed, but this is a more involved change, consult a local expert about that.
- Andrew
Complexity comes for free, Simplicity you have to work for.
How can I prevent changing an EPICS motor record’s commanded position (.VAL field) without disabling the axis?
Thank you,
Ray
Ray Gregory
Oak Ridge National Laboratory
- preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Re: Multiple layers of DB templates? Gregory, Ray via Tech-talk
<2023>
2025
2026
Re: preventing changing an EPICS motor's commanded position Kevin Peterson via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
