1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: DBRecord <-> PVRecord data exchange
From: Joao Paulo Martins via Tech-talk <[email protected]>
Date: Thu, 5 Oct 2023 15:44:57 +0000
Hello Ignacio,
It depends on exactly what you want to achieve. If you want to create a Normative Types PV from your regular EPICS database, you might want to use the PV groups [1].
You also can do a lot by using PVA links [2] in your database records.
In the example below you would read from PVA to a longin record:
record(longin, "$(P)$(R)DBRInput") {
    field(DESC, "Copy of PVAInput")
    field(INP,  {pva:{pv:"$(P)$(R)PVAInput",proc:true}})
You can also do the other way around and write to a Normative Types PV:
record(longout, "$(P)$(R)DBROut") {
    field(DESC, "write using PVA")
    field(OUT,  {pva:{pv:"$(P)$(R)PVAOut"}})
PVA links are available in the pva2pva library that is part of EPICS Base already, and soon will be also in PVXS (QSRV2).
But if you need at a more "complex" integration, I would definitively go for PVXS inside you IOC [3]. You can use the aSub record to read from your regular DBR PVs (records) and from there you can use the SharedPV class from PVXS to do whatever you want. Bruno Martins has a very nice example [4]. If your "old" IOC runs EPICS Base 7+ and QSRV is enabled, it is already producing Normative Types PVs that could be accessed by a PVXS client context via read (get) and subscription (monitor) operations inside the same IOC.
[1] - https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_group_def
[2] - https://epics-base.github.io/pva2pva/qsrv_page.html#qsrv_link
[3] - https://indico.fnal.gov/event/58280/contributions/264559/
[4] - https://github.com/brunoseivam/tabulator/blob/main/stackerApp/src/stackerSup.cpp
Kind regards,
João Paulo Martins
European Spallation Source ERIC
From: Tech-talk <[email protected]> on behalf of Ignacio Arriagada via Tech-talk <[email protected]>
Sent: Wednesday, October 4, 2023 5:38:50 PM
To: [email protected]
Subject: DBRecord <-> PVRecord data exchange
Hello Tech-Talk!
I'm trying to integrate PVAccess (or PVXS) capabilities into an old IOC.
  • What would be the best way to exchange data between the old DBRecords and the new PVRecords with custom data structures, within the same IOC?
  • Do I need to set up a pvClient within the same ioc?
  • Does the exchange need to be done via PVAccess connections or is there an internal way of doing it?
I've been reading Marty Kraimer EPICSV4 developers guide and associated git examples. I'm also consulting Michael Davidsaver's PVXS documentation but it is not clear to me yet how to accomplish this. Are there other resources or examples that I could access regarding this topic?
Thank you all in advance,
Ignacio
Re: DBRecord <-> PVRecord data exchange Ignacio Arriagada via Tech-talk
Prev: Provision for alying sound file in CS-Studio Anindya Roy via Tech-talk
Next: P545 IOC Ernesto Paiser via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: DBRecord <-> PVRecord data exchange Ignacio Arriagada via Tech-talk
Next: Re: DBRecord <-> PVRecord data exchange Ignacio Arriagada via Tech-talk
