Hi Lucas, On Mon, 9 Oct 2023 at 11:46, Lucas Russo via Tech-talk <tech-talk at aps.anl.gov> wrote:
In the EPICS build system, the default target for make is to build and install the module. For that, the user running make needs to have write access to the INSTALL_LOCATION. (And to the parent if INSTALL_LOCATION does not exist.) The EPICS build system will not remove the INSTALL_LOCATION itself, so creating that directory and changing the ownership (and/or access bits) is a one-time thing. FINAL_LOCATION is for cases where the build needs be installed in a location that is not the final one. E.g., when building system packages, where the build is installed in a temporary place but the resulting system package will install it in a different location. Cheers, ~Ralph
ANJ, 09 Oct 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
