1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Opening Multiple Phoebus Instances
From: James Maxwell via Tech-talk <[email protected]>
Date: Wed, 18 Oct 2023 16:38:48 +0000
Hi all,
I've been unable to find a solution to what I think should be an easy problem. I'm using a new install of Ubuntu and a new install of Phoebus.
If I have an instance of Phoebus open, I can't open another one. If I run phoebus.sh, it attempts to show me the existing main window. This even happens if I run it from a different install directory on another user. I've tried using:
phoebus.sh -resource file:/full/path/to/file?target=window
No dice. I've tried starting Phoebus in server mode and not. I can't pop another Phoebus window in a different VNC desktop, or in an x-forward. I feel like I'm missing something big, so I apologize for bothering you.
Secondary question: I can't seem to use Phoebus over XPRA either. I can pop an xterm, but if that xterm runs Phoebus, I get the CSS splash screen, then it crashes with an error "xpra server does not support xi input devices".
Thanks for any help you can provide,
James Maxwell
Jefferson Lab
Re: Opening Multiple Phoebus Instances Kasemir, Kay via Tech-talk
Prev: Re: [External] Alternative Glassman PS FJ option Leblanc, Gregory via Tech-talk
Next: Re: [External] Alternative Glassman PS FJ option Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: External: Re: [External] Alternative Glassman PS FJ option Niko Kivel via Tech-talk
Next: Re: Opening Multiple Phoebus Instances Kasemir, Kay via Tech-talk
