Subject: |
Re: MBBO IVOA has different behavior in IOC shell and Unix terminal |
Rolf Keitel via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 18 Oct 2023 11:52:48 -0700 |
Title: signature text
Hello Marco,
The record, as you defined below, uses string values where
numerical values are required.
If you define the record "record_name" as you describe, you
should get an error message on the IOC console when your database
is loaded. Something like:
"Error: syntax error ....."
This is because the fields ZRVL, ONVL, ... are of type ULONG. If
you set them to a string value, which cannot be decoded into an
integer, the IOC will load the database with an error message and
will set ZRVL, ... to 0.
You can achieve what you want to do (limit the operational value)
by:
- setting ZRVL, ONVL, ... to numerical values
- setting the severities for the states which should not drive
the output (e.g. FRSV, FVSV, ...) to INVALID
- setting IVOA to "Dont
drive outputs" as you did (I believe you were just lucky that
the string "1" is decoded as enumerated 1)
For example, if you define
record(mbbo,
"record_name") {
field(DESC, "description")
field(ZRST, "zero_string") field(ZRVL, 11)
field(ONST, "one_string") field(ONVL,13)
field(TWST, "two_string") field(TWVL, 15)
field(THST, "three_string") field(THVL, 17)
field(FRST, "four_string") field(FRVL, 19)
field(FRSV, INVALID)
field(IVOA, 1)
Now if you do a
caput record_name 4
in a linux shell or a
dbpf record_name 4
on the IOC console, the record's VAL field will be 19, but the
OUT link will not be processed.
HTH - rolf -
On 2023-10-17 6:24 a.m., Marco A. Barra
Montevechi Filho via Tech-talk wrote:
Hello all. I stumbled upon a curious behavior of mbbo record
with configured IVOA field, both in EPICS 3.15.6 and 7.0.7
We were originally testing it in an areaDetector IOC, but
managed to make a minimal example. Basically, we want to set
forbidden values to mbbo record in such a way that the IOC does
not accept values above a certain number (in the example, above
or equal to five).
I defined the following record:
record(mbbo,
"record_name") {
field(ZRST, "zero_string") field(ZRVL, "zero_value")
field(ONST, "one_string") field(ONVL, "one_value")
field(TWST, "two_string") field(TWVL, "two_value")
field(THST, "three_string") field(THVL, "three_value")
field(FRST, "four_string") field(FRVL, "four_value")
field(IVOA, "1")
By configuring the IVOA field to "Dont drive outputs", i
expect that whenever i put 5 into record_name, it does nothing
and statys in the old value. This works in ioc shell:
epics> dbpf record_name 3
DBF_STRING:
"three_string"
epics>
dbgf record_name
DBF_STRING:
"three_string"
epics>
dbpf record_name 7
recGblRecordError:
7 Illegal choice PV: record_name
DBF_STRING:
"three_string"
epics>
dbgf record_name
DBF_STRING:
"three_string"
However, in a linux terminal with caget and caput this is not
true:
marco@s-swc10-l:~$ caget record_name
record_name
three_string
marco@s-swc10-l:~$
caput record_name 7
Warning:
enum index value '7' may be too large.
Old
: record_name three_string
New
: record_name
marco@s-swc10-l:~$
caget record_name
record_name
marco@s-swc10-l:~$
And it changes the value to zero. Even worse: when in an asyn
IOC, the value passed to writeInt32 asyn function is also
zero.
Is there any better way to set an operational limit to mbbo?
Am i missing something?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus
anexos podem conter informações confidenciais e/ou de uso
restrito. Observe atentamente seu conteúdo e considere
eventual consulta ao remetente antes de copiá-la, divulgá-la
ou distribuí-la. Se você recebeu esta mensagem por engano,
por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its
attachments may contain confidential and/or privileged
information. Observe its content carefully and consider
possible querying to the sender before copying, disclosing
or distributing it. If you have received this email by
mistake, please notify the sender and delete it immediately.
Rolf Keitel, Ph.D.
Researcher Emeritus
e-mail: [email protected]
------ Home ------
4158 West 13th Ave
Vancouver, BC, V6R 2T6
604 228 0594
------ Office: ------
604 222 7453
TRIUMF Canada’s particle accelerator centre
4004 Wesbrook Mall Vancouver, BC, V6T 2A3
www.triumf.ca | Twitter | Facebook | Instagram
TRIUMF is located on the traditional, ancestral, and
unceded territory of the xʷməθkʷəy̓əm (Musqueam) people,
who for millennia have passed on their culture, history, and
traditions from one generation to the next on this site.
- Re: MBBO IVOA has different behavior in IOC shell and Unix terminal Marco A. Barra Montevechi Filho via Tech-talk
- MBBO IVOA has different behavior in IOC shell and Unix terminal Marco A. Barra Montevechi Filho via Tech-talk
Re: External: Re: [External] Alternative Glassman PS FJ option Niko Kivel via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
