1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: modbus reading arrays of floats
From: "Pearson, Matthew via Tech-talk" <[email protected]>
Date: Thu, 19 Oct 2023 22:12:39 +0000
I have a device which supports reading arrays of floats (IEEE Float32) over Modbus/TCP.
Am I right in thinking that currently this isn’t supported by the Asyn modbus support? It seems to support arrays of ints, but not floats.
Interestingly, this almost works:
record(waveform, "$(P)$(R)TCA") {
  field(FTVL,  "ULONG")
  field(DTYP,  "asynInt32ArrayIn")
  field(INP,   "@asyn($(PORT)8w4,2064,1)FLOAT32_LE")
By specifying the datatype to be FLOAT32_LE, the modbus driver correctly converts the byte data to floats, but the waveform only gives me the integer part of the number.
So as a work-around I’ve implement multiple reads, one per Float32. This works fine, and I’ll likely stick with it.
However, is there a smarter workaround? For example, can I read the data as a block of Ints, then convert to IEEE Float32 in the database (without writing a subroutine)?
Cheers,
Matt
Re: modbus reading arrays of floats Jemian, Pete R. via Tech-talk
Prev: field transform is not found Tran, Phi Dung via Tech-talk
Next: RE: field transform is not found Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: field transform is not found Mark Rivers via Tech-talk
Next: Re: modbus reading arrays of floats Jemian, Pete R. via Tech-talk
