1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: A Modbus problem relating to byte order and endian
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
Date: Tue, 7 Nov 2023 07:09:13 +0000
Hi, EPICS mates,
I have a motor driver(Oriental AZ series) with built-in encoder.
Its RS-485 2-wire interface is adapted by a MOXA Nport 5150A to ethernet(TCP/IP).
I use Modbus to read its encoder position.
I tested it on my own computer,  and successfully read out the encoder position.
However after transfered to a production EPICS/IOC server, the encoder position value became strange.
Please notice that the versions of modbus module are different.
On my computer(asyn-4-26, modbus-2-7), the read value is:
decimal -271,289
hex FFFB DC47
On EPICS/IOC server(asyn-R4-42, modbuus-R3-2), the read value is:
decimal 1,205,664,767
hex  47DC FBFF
Following is my settings and EPICS record:
## drvAsynIPPortConfigure("portName", "hostInfo", priority, noAutoConnect, noProcessEos)
drvAsynIPPortConfigure("AZPORT01","192.168.2.61:4001",0,0,1)
## modbusInterposeConfig("portName", linkType, timeoutMsec, writeDelayMsec)
modbusInterposeConfig("AZPORT01", 1, 1000, 100)
##drvModbusAsynConfigure("portName", "tcpPortName",slaveAddress, modbusFunction, modbusStartAddress, modbusLength, dataType, pollMsec, "plcType")
drvModbusAsynConfigure("AZPORT01_CH1ENC",   "AZPORT01",    1, 0x03,  0x00CC, 0x02,    6, 100, "AZPORT01")
record(longin, "$(P)$(R)Xenc") {
    field(DTYP, "asynInt32")
    field(INP, "@asyn($(PORT)_CH1ENC 0)MODBUS_DATA")
    field(SCAN, "I/O Intr")
By the way, if I changed the "dataType" from 6(INT32_BE) to 5(INT32_LE), the value became:
decimal -599,261,189
hex  DC47 FFFB
Best regards.
LiangChih Chiang
NSRRC beamline group
email: [email protected]
Re: A Modbus problem relating to byte order and endian Maren Purves via Tech-talk
Prev: Re: AlliedVision Manta G-235B Miroslaw Dach via Tech-talk
Next: Re: A Modbus problem relating to byte order and endian Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Olog usage Timo Korhonen via Tech-talk
