Hi there!
This was an inconsistency I noticed in caget. The help output lists
multiple DBR_...INT types as options for caget's -d option, but none of
them work, because the dbr_text array from
modules/ca/src/client/access.cpp includes only DBR_...SHORT strings.
Would it be okay to simply remove the INT options from the help output
entirely? Or should the tool try and replace "INT" for "SHORT", similar
to how it adds "DBR_" when it doesn't find a match at first?
Somewhat related to that, it seems a bit confusing that some pieces of
code use DBR_INT instead of standardizing on DBR_SHORT. Would a patch
moving everything to DBR_SHORT be of interest?
Cheers,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: caget -d DBR_...INT doesn't work Michael Davidsaver via Tech-talk
second relative motion stuck in a do loop Tran, Phi Dung via Tech-talk
CS-Studio XY Graph problem with >2046 samples Heesterman, Peter via Tech-talk
<2023>
2025
2026
Re: second relative motion stuck in a do loop Kevin Peterson via Tech-talk
<2023>
2025
2026
