1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 24 Nov 2023 09:18:36 +0100
WSL is not an officially supported platform for EPICS Base.
In the past, I found that while generally behaving and acting like a Linux system, WSL shows subtle differences in the implementation of low-level interfaces and services. (In the networking domain, this seems related to WSL using the Windows TCP/IP stack.)
You seem to have found one of those subtleties.
For compatibility, using a VM might be a better option.
Cheers,
~Ralph
SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Prev: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Ralph Lange via Tech-talk
Next: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
