1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: maxnet encoder problem
From: Kevin Peterson via Tech-talk <[email protected]>
To: 백호령 <[email protected]>, [email protected]
Date: Mon, 27 Nov 2023 09:28:03 -0600
No one has reported encoder problems with the MAXnet support, so I suspect it might be a configuration problem.
What is the init string argument to the omsMaxNetConfig call?
https://github.com/epics-motor/motorOmsAsyn/blob/fa94d1dfb5051591783637e137ebb16166590f8e/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/MAXnet.cmd#L25
Which axis is misbehaving?
Kevin
On 11/19/23 18:21, 백호령 via Tech-talk wrote:
As I result of my search, i understand that OMS's MAXv and MAXnet can be used as the motorOmsAsyn of the epics motor module. For MAXv, the encoder pulse value is read correctly, but for MAXnet, the encoder pulse value is read correctly only at the beginning and splashes ti an odd value at the second move. Is this a problem with epics code?Or should I thinj of it as a hardware problem and solve it?
Thank you for your help.
Baeg.
maxnet encoder problem 백호령 via Tech-talk
Prev: Re: PiezosystemJena NV40/3 CLE Kevin Peterson via Tech-talk
Next: support for the QuTools quDis interferometer Chitra Venkataraman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: maxnet encoder problem 백호령 via Tech-talk
Next: PiezosystemJena NV40/3 CLE Graeme Elliner via Tech-talk
