1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted
To: "Wlodek, Jakub" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 29 Nov 2023 19:53:07 +0000
If it was previously working OK and you did not move the card, then it is unlikely to be a PCIe bandwidth issue.  It seems more likely a hardware problem.
When my card was in an x4 slot it had horizontal black stripes that are mainly visible when the field of view is changing.  If the image is static then they are not seen.
Sent: Wednesday, November 29, 2023 1:44 PM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted
Hi Mark,
I believe this is the Cyton CXP2 card:https://www.bitflow.com/products/coaxpress/cyton-cxp2/
Is there a way to confirm that the card is dropping packets?
According to lspci -vvv output, it looks like it is on an x8 width bus  I am using a PCI riser card to fit it into the server, maybe that can be causing issues?
37:00.0 Unassigned class [ff04]: BitFlow Inc Device 7002 (rev 01)
        Physical Slot: 2
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin A routed to IRQ 30
        NUMA node: 0
        Region 0: Memory at e4000000 (32-bit, non-prefetchable) [size=1M]
        Region 1: Memory at e3000000 (32-bit, non-prefetchable) [size=16M]
        Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [78] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [80] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 75.000W
                DevCtl: CorrErr- NonFatalErr+ FatalErr+ UnsupReq-
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
                        MaxPayload 256 bytes, MaxReadReq 4096 bytes
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #1, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s (ok), Width x8 (ok)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR-
                         10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- OBFF Disabled,
                         AtomicOpsCtl: ReqEn-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance De-emphasis: -6dB
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [100 v1] Virtual Channel
                Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
                Arb:    Fixed- WRR32- WRR64- WRR128-
                Ctrl:   ArbSelect=Fixed
                Status: InProgress-
                VC0:    Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
                        Arb:    Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
                        Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
                        Status: NegoPending- InProgress-
        Kernel driver in use: bitflow
Thanks for the help,
Jakub
Sent: Wednesday, November 29, 2023 12:50 PM
To: Wlodek, Jakub <[email protected]>; [email protected] <[email protected]>
Which BitFlow card is this?  I have seen stripes on their Claxon CoaxPress card when it was plugged into an x4 rather than x8 PCIe slot.  They are due to dropped packets.
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Wednesday, November 29, 2023 9:17 AM
To: [email protected]
Subject: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted
Hi all,
Recently I configured an Andor Marana detector utilizing the Andor3 areaDetector driver and the bitflow kernel driver included with the andor3 SDK. This has been working fine and collecting data for ~6 months. At one point, after the detector had been running for a long time, the beamline reported that the IOC was displaying images that appeared corrupted/didn't make sense, but stopping/starting acquisition got back the expected readout, and they ran OK for another several months.
Now, however, this same corrupted image issue has re-emerged, but this time a stop/start does not fix it. In fact, a camera power cycle, IOC reboot, kernel driver rebuild and reload, and IOC server reboot do not appear to have solved the problem. The IOC can detect and connect to the camera, all firmware/serial number information is correct, and it gets images of the correct size, but they do not appear to be valid images. The different PreAmp Gain modes produce different issues, please take a look at the linked github gist for screenshots:
The 12 bit mode exhibits vertical stripe artifacts, while the 16 bit HDR mode exhibits horizontal lines that cross the image. The overall average pixel value in the 16 bit mode with no beam used to be ~100 counts, it is now ~35 counts, and spikes to 200 when the artifacts appear. I don't see any error messages that would explain this in the IOC shell, and during acquisition the detector outputs the correct framerate and image dimensions. The image also does not appear to be influenced by outside stimuli i.e. flashlight/beam.
Has anyone seen this on an Andor Marana, or Andor camera in general before? If so, is there a software based fix for this or is this a hardware related issue? My next troubleshooting steps will probably be to pull out the PCI card and test the setup on a Windows machine with a shorter cable (the bitflow software on windows lets you collect images outside of the Andor SDK), but if this is some kind of configuration issue I'm missing I'd rather ask first before I pull the card out of the server in the rack.
Thanks in advance for the advice!
Jakub
RE: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Pearson, Matthew via Tech-talk
Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
RE: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Mark Rivers via Tech-talk
Re: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
Prev: Re: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
Next: Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: RE: Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Pearson, Matthew via Tech-talk
