1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: PVXS release 1.3.0
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 12 Dec 2023 21:56:21 -0800
PVXS 1.3.0 is now available (also P4P 4.1.12).  The major addition
is support for PVA links in QSRV2.  I thinks this brings PVXS/QSRV2
to ~feature parity with pva2pva/QSRV1.
Special thanks goes to Simon Rose for his contribution.
Previously, $PVXS_QSRV_ENABLE had to be set to "YES" as opt-in to run
QSRV2.  Beginning with 1.3.0 QSRV2 will enable automatically unless
QSRV1 has been loaded into the same process.  Setting PVXS_QSRV_ENABLE=NO
continues to explicitly disable at runtime
https://mdavidsaver.github.io/pvxs/ioc.html#qsrv-2
download https://github.com/mdavidsaver/pvxs/releases
documentation https://mdavidsaver.github.io/pvxs
release notes https://mdavidsaver.github.io/pvxs/releasenotes.html
Re: PVXS release 1.3.0 Murray, Doug via Tech-talk
PVXS release 1.1.2 Michael Davidsaver via Tech-talk
PVXS release 1.2.0 Michael Davidsaver via Tech-talk
Prev: How to get current project location path in javascript ? Philippe della Faille via Tech-talk
Next: Web Proxy being used with PVWS Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: PVXS release 1.2.0 Michael Davidsaver via Tech-talk
Next: Re: PVXS release 1.3.0 Murray, Doug via Tech-talk
