1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: LabCA for MATLAB Installation error
From: "Siddons, David via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, boj <lister at f77.dk>
Cc: Giovanni Franzini <giovanni.franzini at lnf.infn.it>
Date: Tue, 2 Jan 2024 15:08:59 +0000
Is this the problem?
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m mglue.d -I.
-I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/EPICS/base-3.15.9/include/os/WIN32
-ID:/EPICS/base-3.15.9/include             -I../../ezca
-ID:/Matlab2022a/extern/include    mglue.obj ../mglue.c
The system cannot find the path specified.
Pete.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of boj via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, January 2, 2024 10:02 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Dear all
I am still trying to get LabCA (matlab framework for EPCIS) to work
under windows 10. Based on the input from Freddie, I decided to try with
the Visual Studio compiler.
All went well with compiling the base EPICS, but still no success on the
LabCA (however now new error).
The setup is now
* Windows 10
* Visual Studio 2022 with c++
* Matlab R2022a
* epics-labca-labca_3_8_1
* EPICS version base-3.15.9
* EPICS_HOST_ARCH = windows-x64
Problem now seems to be regarding "No rule to make target 'gitstring.c',
needed by 'gitstring.obj'"  (full output from Make below)
I would be very happy if anyone which have succeeded in compiling LabCA
under windows 10, could give some hints to which setup works
Best regards
     Bo
Output from make is now:
d:\EPICS\epics-labca-labca_3_8_1>make
process_begin: CreateProcess(NULL, git describe, ...) failed.
makefile:24: pipe: No error
make -C ./configure install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
     T_A=windows-x64 install
make[2]: Entering directory
'd:/EPICS/epics-labca-labca_3_8_1/configure/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl
checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
make -C ./ezca install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/ezca/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ezca.d -I.
-ID:/EPICS/base-3.15.9/include                 ezca.obj ../ezca.c
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I..
-I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include                 -c ../ezca.c
ezca.c
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(570): warning C4311: 'type
cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(575): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(612): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(618): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(713): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(715): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4905): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4934): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5032): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5034): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5529): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5546): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5590): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5595): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5697): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5716): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5755): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6963): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6999): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7191): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7217): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7263): warning C4311: 'type
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release  -MACHINE:X64      -out:ezcamt.dll -implib:ezcamt.lib
ezca.obj D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib
    Creating library ezcamt.lib and object ezcamt.exp
Generating code
Finished generating code
"Installing shared library ../../bin/windows-x64/ezcamt.dll"
"Installing library ../../lib/windows-x64/ezcamt.lib"
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/glue/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ini.d -I.
-ID:/Matlab2022a/extern/include    ini.obj ../ini.cc
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m multiEzca.d
-I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-ID:/Matlab2022a/extern/include    multiEzca.obj ../multiEzca.c
ctrlC-polled.d -I. -I../O.Common -I. -I. -I..
-I../../include    -ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/Matlab2022a/extern/include    ctrlC-polled.obj ../ctrlC-polled.c
perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
perl > gitstring.c.new -e "print(\"const char *gitRevisionString =
\\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new
perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )'
gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f
gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
') was unexpected at this time.
cl -EHsc -GR          -DMATLAB_APP      -nologo -FC -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-
-W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I..
-ID:/Matlab2022a/extern/include    -c ../ini.cc
ini.cc
cl          -DMATLAB_APP      -nologo -FC -D__STDC__=0
-W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common
-I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32
-ID:/Matlab2022a/extern/include    -c ../multiEzca.c
multiEzca.c
d:\EPICS\epics-labca-labca_3_8_1\glue\multiEzca.c(27): warning C4005:
'isnan': macro redefinition
D:\Windows Kits\10\include\10.0.22621.0\ucrt\corecrt_math.h(280): note:
see previous definition of 'isnan'
D:\Matlab2022a\extern\include\mex.h(197): warning C4005: 'printf': macro
redefinition
D:\EPICS\base-3.15.9\include\epicsStdio.h(41): note: see previous
definition of 'printf'
-ID:/Matlab2022a/extern/include    -c ../ctrlC-polled.c
ctrlC-polled.c
make[2]: *** No rule to make target 'gitstring.c', needed by
'gitstring.obj'.  Stop.
make[1]: *** [D:/EPICS/base-3.15.9/configure/RULES_ARCHS:58:
install.windows-x64] Error 2
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: glue.install]
Error 2
On 19-12-2023 13:02, Freddie Akeroyd - STFC UKRI wrote:
> Hi Boj,
> I'm not a user of labca, but we do use EPICS on windows and I have used matlab in the past, so I'm basing my answers on this rather than anything I can actually test for you unfortunately
> The program is failing to link as it cannot find some functions from the matlab mex/mx libraries, I see that libmx.lib and libmex.lib are included on the command line but these files will be in Microsoft import library format and gcc/mingw didn't used to read this format, hence why you may be getting undefined symbols. Normally with gcc/mingw  you would be linking as e.g.  -lmex   and it would locate a  libmex.dll.a file to reference libmex.dll    If you were using the visual studio window compiler then it may work better as .lib is its native format. Does matlab provide *.dll.a files or just *.lib and *.dll ? You can create a mingw compatible .dll.a file the following way from the mingw shell
>      # create libmex.def
>      gendef libmex.dll
>      # create libmex.dll.a from libmex.def
>      dlltool --def libmex.def  --output-lib libmex.dll.a
> (in some cases the -k argument may also be needed with dlltool, add that if you still get link undefined errors using libmex.dll.a)
> At one point I think it was possible to link directly against a dll in mingw and it would auto import, but I am not sure if that is still the case i.e. You would link against /d/Matlab2022a/extern/lib/win64/mingw64/libmx.dll rather than /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib  however creating a .dll.a is probably the better approach
> Regards,
> Freddie
>> -----Original Message-----
>> From: boj <lister at f77.dk>
>> Sent: 19 December 2023 10:45
>> To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
>> Cc: Giovanni Franzini <giovanni.franzini at lnf.infn.it>; tech-talk at aps.anl.gov
>> Dear Freddie and all
>> I looked a bit more carefully at the errors, and here are some details,
>> unfortunately I am not very skilled in either c/c++ programming or windows
>> programming, so that makes it hard for me to understand what is important.
>> The setup is:
>> * Windows 10
>> * MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
>> * Matlab R2022a
>> In the labca source code I have set
>> configure/RELEASE
>>       BASE_SUBDIR=
>>       EPICS_BASE=/home/boj/base-3.15.9/
>>       MATLABDIR = /d/Matlab2022a
>>       MATLIB_SUBDIR=win64/mingw64
>> In my .bash_profile for MSYS2 I have
>>       EPICS_HOST_ARCH=windows-x64-mingw
>>       PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
>> EPICS  command line tools works
>> Included at the end of this mail is the full output of make, but as I understand
>> it the problem is in the linking of mezcaglue.dll I get:
>> gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -
>> Wall      -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I.
>> -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include    -
>> I/home/boj/base-3.15.9/include/compiler/gcc
>> -I/home/boj/base-3.15.9/include/os/WIN32
>> -I/home/boj/base-3.15.9/include             -I../../ezca -
>> I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
>> g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a
>> -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw
>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw
>> /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib
>> /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64 ini.obj
>> multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj -lezcamt -lca -lCom  -
>> luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-
>> mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
>> : ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
>> : ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
>> Which then continues with  "undefined reference to `XXXX" for many lines and
>> end with
>> collect2.exe: error: ld returned 1 exit status
>> make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292:
>> mezcaglue.dll] Error 1
>> '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
>> make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58:
>> install.windows-x64-mingw] Error 2
>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
>> make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install]
>> Error 2
>> I hope this makes sence, and maybe can give a hint to what I am dooing
>> wrong.
>> Best regards
>>       Bo
>> Full output of make:
>> boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1 $ make
>> make: git: No such file or directory
>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl
>> O.windows-x64-mingw ../..
>> perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-
>> x64-mingw -f ../Makefile TOP=../.. \
>>       T_A=windows-x64-mingw install
>> '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl
>> checkRelease
>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>> '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
>> gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
>> -I/home/boj/base-3.15.9/include                  -MM -MF ezca.d -MT ezca.obj
>> ../ezca.c gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
>> -I/home/boj/base-3.15.9/include                 -o ezca.obj -c ../ezca.c
>> ../ezca.c: In function 'ezcaLock':
>> ../ezca.c:89:25: warning: cast from pointer to integer of different size [-
>> Wpointer-to-int-cast]
>>      89 |                         (unsigned long)epicsThreadGetIdSelf()); \
>> ../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
>>     570 |         EZCA_LOCK();
>> ../ezca.c: In function 'ezcaUnlock':
>> ../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
>>     575 |         EZCA_LOCK();
>> ../ezca.c: In function 'ezcaPollCbInstall':
>> ../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
>>     612 |         EZCA_LOCK();
>> ../ezca.c:611:1: warning: this 'if' clause does not guard...
>> [-Wmisleading-indentation]
>>     611 | if ( (i=Initialized) )
>> ../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented
>> as if it were guar ded by the 'if'
>>     614 |         rval = pollCb;
>> ../ezca.c:97:25: warning: cast from pointer to integer of different size [-
>>      97 |                         (unsigned long)epicsThreadGetIdSelf()); \
>> ../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
>>     618 |         EZCA_UNLOCK();
>> ../ezca.c:617:1: warning: this 'if' clause does not guard...
>>     617 | if (i)
>> ../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented
>>     620 |         return rval;
>> ../ezca.c: In function 'ezcaEndGroupWithReport':
>> ../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
>>     713 |                                 EZCA_LOCK(); /* make *sure* mutex is not
>> relinquished by add ing a nest count */
>> ../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
>>     715 |                                 EZCA_UNLOCK();
>> ../ezca.c:966:13: warning: this 'if' clause does not guard...
>>     966 |             if (Trace || Debug)
>> ../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented
>> as if it were gua rded by the 'if'
>>     104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) )
>> ca_flush_io(); } while (0)
>> ../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
>>     969 |                 MARK_OUTSTANDING(needs_work);
>> ../ezca.c:1063:29: warning: this 'if' clause does not guard...
>>    1063 |                             if (AutoErrorMessage)
>> ../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly
>> indented as if it were gu arded by the 'if'
>>    1066 |                                 if ( MONBLOCK == wp->worktype && wp->pval )
>> ../ezca.c: In function 'prologue':
>> ../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
>>    4905 |         EZCA_LOCK();
>> ../ezca.c: In function 'epilogue':
>> ../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
>>    4934 |         EZCA_UNLOCK();
>> ../ezca.c: In function 'EzcaClearChannel':
>> ../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
>>    5032 |         EZCA_UNLOCK();
>> ../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
>>    5034 |         EZCA_LOCK();
>> ../ezca.c: In function 'EzcaPendEvent':
>> ../ezca.c:5519:5: warning: this 'if' clause does not guard...
>>    5519 |     if (Trace || Debug)
>> ../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented
>>    5522 |         if ( pollCb && pollCb() ) {
>> ../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    5529 | EZCA_UNLOCK();
>> ../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
>>    5546 | EZCA_LOCK();
>> ../ezca.c: In function 'EzcaPendIO':
>> ../ezca.c:5584:5: warning: this 'if' clause does not guard...
>>    5584 |     if (Trace || Debug)
>> ../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented
>>    5587 |         if ( pollCb && pollCb() ) {
>> ../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    5590 | EZCA_UNLOCK();
>> ../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
>>    5595 | EZCA_LOCK();
>> ../ezca.c: In function 'my_connection_callback':
>> ../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
>>    5697 | EZCA_LOCK();
>> ../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    5716 | EZCA_UNLOCK();
>> ../ezca.c: In function 'my_get_callback':
>> ../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
>>    5755 | EZCA_LOCK();
>> ../ezca.c:6949:13: warning: this 'if' clause does not guard...
>>    6949 |             if (Trace || Debug)
>> ../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly
>>    6951 |                 recycle_work(wp);
>> ../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    6963 | EZCA_UNLOCK();
>> ../ezca.c: In function 'my_monitor_callback':
>> ../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
>>    6999 | EZCA_LOCK();
>> ../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    7191 | EZCA_UNLOCK();
>> ../ezca.c: In function 'my_put_callback':
>> ../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
>>    7217 | EZCA_LOCK();
>> ../ezca.c:7249:13: warning: this 'if' clause does not guard...
>>    7249 |             if (Trace || Debug)
>> ../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly
>>    7251 |                 recycle_work(wp);
>> ../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
>>    7263 | EZCA_UNLOCK();
>> ../ezca.c: In function 'print_discarded_channels':
>> ../ezca.c:7886:5: warning: this 'for' clause does not guard...
>>    7886 |     for (cp = Discarded_channels; cp; cp = cp->next)
>> ../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented
>> as if it were gua rded by the 'for'
>>    7888 |         printf("\n");
>> g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a
>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64
>> ezca.obj    -lca -lCom      -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>> Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
>> mkdir ../../bin
>> mkdir ../../bin/windows-x64-mingw
>> Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
>> mkdir ../../lib
>> mkdir ../../lib/windows-x64-mingw
>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
>> make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
>> g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3
>> -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common
>> -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
>> -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc
>> -I/d/Matlab2022a/extern/include     -MM -MF ini.d -MT ini.obj ../ini.cc
>> -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
>> -I/d/Matlab2022a/extern/include     -MM -MF multiEzca.d -MT
>> -I/d/Matlab2022a/extern/include     -MM -MF ctrlC-polled.d -MT
>> -I/d/Matlab2022a/extern/include     -MM -MF gitstring.d -MT
>> gitstring.obj gitstring.c
>> -I/d/Matlab2022a/extern/include     -MM -MF mglue.d -MT mglue.obj
>> ../mglue.c
>> -I/d/Matlab2022a/extern/include    -o ini.obj -c ../ini.cc
>> -I/d/Matlab2022a/extern/include    -o multiEzca.obj -c ../multiEzca.c
>> ../multiEzca.c:27: warning: "isnan" redefined
>>      27 | #define isnan _isnan
>> In file included from ../multiEzca.c:13:
>> C:/msys64/mingw64/include/math.h:586: note: this is the location of the
>> previous definition
>>     586 | #define isnan(x) \
>> In file included from ../multiEzca.c:32:
>> D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
>>     197 | #define printf mexPrintf
>> In file included from ../multiEzca.c:24:
>> C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is
>> the location of the previous d
>> efinition
>>      41 | #  define printf epicsStdoutPrintf
>> -I/d/Matlab2022a/extern/include    -o ctrlC-polled.obj -c ../ctrlC-polled.c
>> -I/d/Matlab2022a/extern/include    -o gitstring.obj -c gitstring.c
>> -I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
>> ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj
>> -lezcamt -lca -lCom  -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32
>> -lwinmm
>> : ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
>> : ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
>> : ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
>> : ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0x5d0): undefined reference to
>> `mexCallMATLABWithTrap_800'
>> : ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
>> : ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
>> : ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
>> : ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
>> : ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
>> : ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
>> : ini.obj:ini.cc:(.text+0x997): undefined reference to
>> : ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
>> : ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
>> : ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
>> : ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
>> : ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
>> : ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
>> : ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to
>> `mexPrintf_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to
>> `mxCalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to
>> `mxFree_800' follow
>> : multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to
>> `mxCalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to
>> `mexPrintf_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to
>> `mxCalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to
>> `mxCalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to
>> `mxMalloc_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to
>> `mxFree_800'
>> : multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to
>> `mxFree_800' follow
>> : ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to
>> `utHandlePendingInterrupt'
>> : mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
>> : mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
>> : mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
>> : mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
>> : mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
>> : mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
>> : mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
>> : mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
>> : mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
>> : mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
>> : mglue.obj:mglue.c:(.text+0x510): undefined reference to
>> : mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
>> : mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
>> : mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
>> : mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
>> : mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
>> : mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
>> : mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
>> : mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
>> : mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
>> : mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x6b3): undefined reference to
>> : mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
>> : mglue.obj:mglue.c:(.text+0x71b): undefined reference to
>> `mxCreateCellMatrix_800'
>> : mglue.obj:mglue.c:(.text+0x732): undefined reference to
>> `mxDuplicateArray_800'
>> : mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
>> : mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
>> : mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
>> : mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
>> Error 2
>> On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
>>> Hi Bo,
>>> Do you see the same error as Giovanni saw, or are you getting a different
>> build failure?
>>> Regards,
>>> Freddie
Re: LabCA for MATLAB Installation error boj via Tech-talk
Prev: Re: LabCA for MATLAB Installation error boj via Tech-talk
Next: RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
