1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: LabCA for MATLAB Installation error
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Cc: Giovanni Franzini <[email protected]>
Date: Wed, 3 Jan 2024 12:25:15 +0000
Yes https://github.com/till-s/epics-labca/blob/7915ca4769f49eee1ceba77493ee3cda6bf2a51b/glue/Makefile#L204  uses "(" to run commands in a subprocess and that is /bin/sh specific
Bo, does applying this change help?
https://github.com/till-s/epics-labca/compare/master...FreddieAkeroyd:epics-labca:fix_windows_quoting
Freddie
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
Sent: 03 January 2024 01:29
Cc: Giovanni Franzini <[email protected]>; [email protected]
Subject: Re: LabCA for MATLAB Installation error
On 1/2/24 08:28, Mark Rivers via Tech-talk wrote:
> Hi Bo,
> The fatal error you are getting is because gitstring.c does not exist.  But I think that is due to a non-fatal error earlier in the output:
> perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )'
> gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f
> gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
> ') was unexpected at this time.
Isn't "... was unexpected at this time" a cmd shell error?
I guess this Makefile assumes SHELL=/bin/sh ?
> So I think it is trying to rename gitstring.c.new to gitstring.c and that is failing.  I think a perl expert is needed to help here?
> Mark
> From: Tech-talk <[email protected]> On Behalf Of boj via Tech-talk
> Sent: Tuesday, January 2, 2024 9:03 AM
> To: [email protected]
> Dear all
> I am still trying to get LabCA (matlab framework for EPCIS) to work
> under windows 10. Based on the input from Freddie, I decided to try with
> the Visual Studio compiler.
> All went well with compiling the base EPICS, but still no success on the
> LabCA (however now new error).
> The setup is now
> * Windows 10
> * Visual Studio 2022 with c++
> * Matlab R2022a
> * epics-labca-labca_3_8_1
> * EPICS version base-3.15.9
> * EPICS_HOST_ARCH = windows-x64
> Problem now seems to be regarding "No rule to make target 'gitstring.c',
> needed by 'gitstring.obj'"  (full output from Make below)
> I would be very happy if anyone which have succeeded in compiling LabCA
> under windows 10, could give some hints to which setup works
> Best regards
>       Bo
> Output from make is now:
> d:\EPICS\epics-labca-labca_3_8_1>make
> The system cannot find the path specified.
> process_begin: CreateProcess(NULL, git describe, ...) failed.
> makefile:24: pipe: No error
> make -C ./configure install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl
> O.windows-x64 ../..
> perl -CSD -MExtUtils::Command -e mkpath O.Common
> make -C O.windows-x64 -f ../Makefile TOP=../.. \
>       T_A=windows-x64 install
> make[2]: Entering directory
> 'd:/EPICS/epics-labca-labca_3_8_1/configure/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl
> checkRelease
> echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
> make[2]: Leaving directory
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
> make -C ./ezca install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
> O.windows-x64 ../..
> 'd:/EPICS/epics-labca-labca_3_8_1/ezca/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ezca.d -I.
> -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
> -I../../include/os/WIN32 -I../../include
> -ID:/EPICS/base-3.15.9/include/compiler/msvc
> -ID:/EPICS/base-3.15.9/include/os/WIN32
> -ID:/EPICS/base-3.15.9/include                 ezca.obj ../ezca.c
> cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
> -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD
> -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I..
> -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include
> -ID:/EPICS/base-3.15.9/include                 -c ../ezca.c
> ezca.c
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(570): warning C4311: 'type
> cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(575): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(612): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(618): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(713): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(715): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4905): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4934): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5032): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5034): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5529): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5546): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5590): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5595): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5697): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5716): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5755): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6963): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6999): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7191): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7217): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7263): warning C4311: 'type
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
> -release  -MACHINE:X64      -out:ezcamt.dll -implib:ezcamt.lib
> ezca.obj D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
> D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib
>      Creating library ezcamt.lib and object ezcamt.exp
> Generating code
> Finished generating code
> "Installing shared library ../../bin/windows-x64/ezcamt.dll"
> "Installing library ../../lib/windows-x64/ezcamt.lib"
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
> make -C ./glue install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
> O.windows-x64 ../..
> 'd:/EPICS/epics-labca-labca_3_8_1/glue/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ini.d -I.
> -ID:/EPICS/base-3.15.9/include             -I../../ezca
> -ID:/Matlab2022a/extern/include    ini.obj ../ini.cc
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m multiEzca.d
> -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
> -ID:/Matlab2022a/extern/include    multiEzca.obj ../multiEzca.c
> ctrlC-polled.d -I. -I../O.Common -I. -I. -I..
> -I../../include    -ID:/EPICS/base-3.15.9/include/compiler/msvc
> -ID:/Matlab2022a/extern/include    ctrlC-polled.obj ../ctrlC-polled.c
> perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
> perl > gitstring.c.new -e "print(\"const char *gitRevisionString =
> \\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m mglue.d -I.
> -ID:/Matlab2022a/extern/include    mglue.obj ../mglue.c
> cl -EHsc -GR          -DMATLAB_APP      -nologo -FC -D__STDC__=0
> -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-
> -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL
> -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I..
> -ID:/Matlab2022a/extern/include    -c ../ini.cc
> ini.cc
> cl          -DMATLAB_APP      -nologo -FC -D__STDC__=0
> -W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common
> -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32
> -ID:/Matlab2022a/extern/include    -c ../multiEzca.c
> multiEzca.c
> d:\EPICS\epics-labca-labca_3_8_1\glue\multiEzca.c(27): warning C4005:
> 'isnan': macro redefinition
> D:\Windows Kits\10\include\10.0.22621.0\ucrt\corecrt_math.h(280): note:
> see previous definition of 'isnan'
> D:\Matlab2022a\extern\include\mex.h(197): warning C4005: 'printf': macro
> redefinition
> D:\EPICS\base-3.15.9\include\epicsStdio.h(41): note: see previous
> definition of 'printf'
> -ID:/Matlab2022a/extern/include    -c ../ctrlC-polled.c
> ctrlC-polled.c
> make[2]: *** No rule to make target 'gitstring.c', needed by
> 'gitstring.obj'.  Stop.
> make[1]: *** [D:/EPICS/base-3.15.9/configure/RULES_ARCHS:58:
> install.windows-x64] Error 2
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
> make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: glue.install]
> Error 2
> On 19-12-2023 13:02, Freddie Akeroyd - STFC UKRI wrote:
>> Hi Boj,
>> I'm not a user of labca, but we do use EPICS on windows and I have used matlab in the past, so I'm basing my answers on this rather than anything I can actually test for you unfortunately
>> The program is failing to link as it cannot find some functions from the matlab mex/mx libraries, I see that libmx.lib and libmex.lib are included on the command line but these files will be in Microsoft import library format and gcc/mingw didn't used to read this format, hence why you may be getting undefined symbols. Normally with gcc/mingw  you would be linking as e.g.  -lmex   and it would locate a  libmex.dll.a file to reference libmex.dll    If you were using the visual studio window compiler then it may work better as .lib is its native format. Does matlab provide *.dll.a files or just *.lib and *.dll ? You can create a mingw compatible .dll.a file the following way from the mingw shell
>>       # create libmex.def
>>       gendef libmex.dll
>>       # create libmex.dll.a from libmex.def
>>       dlltool --def libmex.def  --output-lib libmex.dll.a
>> (in some cases the -k argument may also be needed with dlltool, add that if you still get link undefined errors using libmex.dll.a)
>> At one point I think it was possible to link directly against a dll in mingw and it would auto import, but I am not sure if that is still the case i.e. You would link against /d/Matlab2022a/extern/lib/win64/mingw64/libmx.dll rather than /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib  however creating a .dll.a is probably the better approach
>> Regards,
>> Freddie
>>> From: boj <[email protected]>
>>> Sent: 19 December 2023 10:45
>>> To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
>>> Dear Freddie and all
>>> I looked a bit more carefully at the errors, and here are some details,
>>> unfortunately I am not very skilled in either c/c++ programming or windows
>>> programming, so that makes it hard for me to understand what is important.
>>> The setup is:
>>> * Windows 10
>>> * MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
>>> * Matlab R2022a
>>> In the labca source code I have set
>>> configure/RELEASE
>>>        BASE_SUBDIR=
>>>        EPICS_BASE=/home/boj/base-3.15.9/
>>>        MATLABDIR = /d/Matlab2022a
>>>        MATLIB_SUBDIR=win64/mingw64
>>> In my .bash_profile for MSYS2 I have
>>>        EPICS_HOST_ARCH=windows-x64-mingw
>>>        PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
>>> EPICS  command line tools works
>>> Included at the end of this mail is the full output of make, but as I understand
>>> it the problem is in the linking of mezcaglue.dll I get:
>>> gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -
>>> Wall      -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I.
>>> -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include    -
>>> I/home/boj/base-3.15.9/include/compiler/gcc
>>> -I/home/boj/base-3.15.9/include/os/WIN32
>>> -I/home/boj/base-3.15.9/include             -I../../ezca -
>>> I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
>>> g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a
>>> -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw
>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw
>>> /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib
>>> /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64 ini.obj
>>> multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj -lezcamt -lca -lCom  -
>>> luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-
>>> mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
>>> : ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
>>> : ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
>>> Which then continues with  "undefined reference to `XXXX" for many lines and
>>> end with
>>> collect2.exe: error: ld returned 1 exit status
>>> make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292:
>>> mezcaglue.dll] Error 1
>>> '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
>>> make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58:
>>> install.windows-x64-mingw] Error 2
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>> make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install]
>>> Error 2
>>> I hope this makes sence, and maybe can give a hint to what I am dooing
>>> wrong.
>>> Best regards
>>>        Bo
>>> Full output of make:
>>> boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1 $ make
>>> make: git: No such file or directory
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl
>>> O.windows-x64-mingw ../..
>>> perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-
>>> x64-mingw -f ../Makefile TOP=../.. \
>>>        T_A=windows-x64-mingw install
>>> '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl
>>> checkRelease
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>> '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
>>> gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
>>> -I/home/boj/base-3.15.9/include                  -MM -MF ezca.d -MT ezca.obj
>>> ../ezca.c gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
>>> -I/home/boj/base-3.15.9/include                 -o ezca.obj -c ../ezca.c
>>> ../ezca.c: In function 'ezcaLock':
>>> ../ezca.c:89:25: warning: cast from pointer to integer of different size [-
>>> Wpointer-to-int-cast]
>>>       89 |                         (unsigned long)epicsThreadGetIdSelf()); \
>>> ../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
>>>      570 |         EZCA_LOCK();
>>> ../ezca.c: In function 'ezcaUnlock':
>>> ../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
>>>      575 |         EZCA_LOCK();
>>> ../ezca.c: In function 'ezcaPollCbInstall':
>>> ../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
>>>      612 |         EZCA_LOCK();
>>> ../ezca.c:611:1: warning: this 'if' clause does not guard...
>>> [-Wmisleading-indentation]
>>>      611 | if ( (i=Initialized) )
>>> ../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented
>>> as if it were guar ded by the 'if'
>>>      614 |         rval = pollCb;
>>> ../ezca.c:97:25: warning: cast from pointer to integer of different size [-
>>>       97 |                         (unsigned long)epicsThreadGetIdSelf()); \
>>> ../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>      618 |         EZCA_UNLOCK();
>>> ../ezca.c:617:1: warning: this 'if' clause does not guard...
>>>      617 | if (i)
>>> ../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented
>>>      620 |         return rval;
>>> ../ezca.c: In function 'ezcaEndGroupWithReport':
>>> ../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
>>>      713 |                                 EZCA_LOCK(); /* make *sure* mutex is not
>>> relinquished by add ing a nest count */
>>> ../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
>>>      715 |                                 EZCA_UNLOCK();
>>> ../ezca.c:966:13: warning: this 'if' clause does not guard...
>>>      966 |             if (Trace || Debug)
>>> ../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented
>>> as if it were gua rded by the 'if'
>>>      104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) )
>>> ca_flush_io(); } while (0)
>>> ../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
>>>      969 |                 MARK_OUTSTANDING(needs_work);
>>> ../ezca.c:1063:29: warning: this 'if' clause does not guard...
>>>     1063 |                             if (AutoErrorMessage)
>>> ../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly
>>> indented as if it were gu arded by the 'if'
>>>     1066 |                                 if ( MONBLOCK == wp->worktype && wp->pval )
>>> ../ezca.c: In function 'prologue':
>>> ../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
>>>     4905 |         EZCA_LOCK();
>>> ../ezca.c: In function 'epilogue':
>>> ../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>     4934 |         EZCA_UNLOCK();
>>> ../ezca.c: In function 'EzcaClearChannel':
>>> ../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>     5032 |         EZCA_UNLOCK();
>>> ../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
>>>     5034 |         EZCA_LOCK();
>>> ../ezca.c: In function 'EzcaPendEvent':
>>> ../ezca.c:5519:5: warning: this 'if' clause does not guard...
>>>     5519 |     if (Trace || Debug)
>>> ../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented
>>>     5522 |         if ( pollCb && pollCb() ) {
>>> ../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     5529 | EZCA_UNLOCK();
>>> ../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
>>>     5546 | EZCA_LOCK();
>>> ../ezca.c: In function 'EzcaPendIO':
>>> ../ezca.c:5584:5: warning: this 'if' clause does not guard...
>>>     5584 |     if (Trace || Debug)
>>> ../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented
>>>     5587 |         if ( pollCb && pollCb() ) {
>>> ../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     5590 | EZCA_UNLOCK();
>>> ../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
>>>     5595 | EZCA_LOCK();
>>> ../ezca.c: In function 'my_connection_callback':
>>> ../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
>>>     5697 | EZCA_LOCK();
>>> ../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     5716 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_get_callback':
>>> ../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
>>>     5755 | EZCA_LOCK();
>>> ../ezca.c:6949:13: warning: this 'if' clause does not guard...
>>>     6949 |             if (Trace || Debug)
>>> ../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly
>>>     6951 |                 recycle_work(wp);
>>> ../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     6963 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_monitor_callback':
>>> ../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
>>>     6999 | EZCA_LOCK();
>>> ../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     7191 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_put_callback':
>>> ../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
>>>     7217 | EZCA_LOCK();
>>> ../ezca.c:7249:13: warning: this 'if' clause does not guard...
>>>     7249 |             if (Trace || Debug)
>>> ../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly
>>>     7251 |                 recycle_work(wp);
>>> ../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>     7263 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'print_discarded_channels':
>>> ../ezca.c:7886:5: warning: this 'for' clause does not guard...
>>>     7886 |     for (cp = Discarded_channels; cp; cp = cp->next)
>>> ../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented
>>> as if it were gua rded by the 'for'
>>>     7888 |         printf("\n");
>>> g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a
>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64
>>> ezca.obj    -lca -lCom      -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>> Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
>>> mkdir ../../bin
>>> mkdir ../../bin/windows-x64-mingw
>>> Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
>>> mkdir ../../lib
>>> mkdir ../../lib/windows-x64-mingw
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>> make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
>>> g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3
>>> -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common
>>> -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
>>> -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc
>>> -I/d/Matlab2022a/extern/include     -MM -MF ini.d -MT ini.obj ../ini.cc
>>> -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
>>> -I/d/Matlab2022a/extern/include     -MM -MF multiEzca.d -MT
>>> -I/d/Matlab2022a/extern/include     -MM -MF ctrlC-polled.d -MT
>>> -I/d/Matlab2022a/extern/include     -MM -MF gitstring.d -MT
>>> gitstring.obj gitstring.c
>>> -I/d/Matlab2022a/extern/include     -MM -MF mglue.d -MT mglue.obj
>>> ../mglue.c
>>> -I/d/Matlab2022a/extern/include    -o ini.obj -c ../ini.cc
>>> -I/d/Matlab2022a/extern/include    -o multiEzca.obj -c ../multiEzca.c
>>> ../multiEzca.c:27: warning: "isnan" redefined
>>>       27 | #define isnan _isnan
>>> In file included from ../multiEzca.c:13:
>>> C:/msys64/mingw64/include/math.h:586: note: this is the location of the
>>> previous definition
>>>      586 | #define isnan(x) \
>>> In file included from ../multiEzca.c:32:
>>> D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
>>>      197 | #define printf mexPrintf
>>> In file included from ../multiEzca.c:24:
>>> C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is
>>> the location of the previous d
>>> efinition
>>>       41 | #  define printf epicsStdoutPrintf
>>> -I/d/Matlab2022a/extern/include    -o ctrlC-polled.obj -c ../ctrlC-polled.c
>>> -I/d/Matlab2022a/extern/include    -o gitstring.obj -c gitstring.c
>>> -I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
>>> ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj
>>> -lezcamt -lca -lCom  -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32
>>> -lwinmm
>>> : ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x5d0): undefined reference to
>>> `mexCallMATLABWithTrap_800'
>>> : ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
>>> : ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
>>> : ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
>>> : ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
>>> : ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
>>> : ini.obj:ini.cc:(.text+0x997): undefined reference to
>>> : ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
>>> : ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
>>> : ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
>>> : ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
>>> : ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to
>>> `mexPrintf_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to
>>> `mxFree_800' follow
>>> : multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to
>>> `mexPrintf_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to
>>> `mxFree_800' follow
>>> : ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to
>>> `utHandlePendingInterrupt'
>>> : mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x510): undefined reference to
>>> : mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6b3): undefined reference to
>>> : mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x71b): undefined reference to
>>> `mxCreateCellMatrix_800'
>>> : mglue.obj:mglue.c:(.text+0x732): undefined reference to
>>> `mxDuplicateArray_800'
>>> : mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
>>> : mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
>>> Error 2
>>> On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
>>>> Hi Bo,
>>>> Do you see the same error as Giovanni saw, or are you getting a different
>>> build failure?
>>>> Regards,
>>>> Freddie
Re: LabCA for MATLAB Installation error boj via Tech-talk
RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
Re: LabCA for MATLAB Installation error Michael Davidsaver via Tech-talk
Prev: Re: Question about cross compile of epics Ralph Lange via Tech-talk
Next: Re: LabCA for MATLAB Installation error boj via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: LabCA for MATLAB Installation error Michael Davidsaver via Tech-talk
