Hi Mark
Thanks for your response.
Please provide the following:
The versions of ADCore and ADVimba
ADCore - R3-8, ADVimba - Ahead of R1-3 at commit 17dcdb1 dated Jun 30, 2022
Is this Windows or Linux?
How many cores on the IOC machine?
When you say 75% of the CPU do you mean 75% of a single core, or 75% of all cores?
75% of all cores... as evident from command "glances"
When you remove the external trigger what frame rate are the cameras getting? It should be 0.
FrameRate_RBV is 10 (that's what it's set. I tried setting framerate to zero and still the same CPU usage) but ImageRate_RBV
is 0.
A screenshot of the AVVimba screen when the problem is happening
A screenshot of the commonPlugins OPI screen when the problem is happening so we can see what plugins are running and at
what rate.
I am using Trans, Stats, Overlay and NDStdArray Plugins and the rate is 0 under this scenario.
A screenshot of "top -h" in the IOC computer when the problem is happening on. This will show us what threads are using
the CPU.
Many Thanks
Sandeep
Sent: 16 January 2024 20:57
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>; Malu, Sandeep Kumar (-,RAL,CLF) <sandeep-kumar.malu at stfc.ac.uk>
Subject: Re: ADVimba CPU usage
The command I meant is “top -H”, not -h.
On Jan 16, 2024, at 8:47 AM, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Sandeep,
A screenshot of the commonPlugins OPI screen when the problem is happening so we can see what plugins are running and at what
rate.
A screenshot of "top -h" in the IOC computer when the problem is happening on. This will show us what threads are using the
CPU.
I just did a quick test of a GC1380CH camera with ADVimba. It used 30% of 1 core when running
at 30 frames/s. I had only NDPluginPVA running. When I stopped the camera acquisition the CPU dropped to 0%, as I expected. When I selected external trigger but have no trigger pulses arriving I also get 0 frames/s and 0% CPU, as I expect.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sandeep Kumar Malu - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, January 16, 2024 6:08 AM
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: ADVimba CPU usage
Hi All
I have been using ADVimba Areadetector driver for AVT MakoG234C (1936x1216) Cameras. 15 cameras are running with external triggers of 10 fps and the CPU usage is ~27%.
However, when I deployed those 15 cameras keeping the external trigger (from the delay generator) off, the CPU usage drastically goes up to ~75%. Also, I noticed the same behaviour when Acquire is OFF or switched to Software Trigger source.
Has anyone seen this behaviour when the driver is not actually acquiring the images? Is there any solution to this drastic CPU usage?
Many Thanks
Sandeep
Description: ADVimba.png
Description: topH.png
- Re: ADVimba CPU usage Mark Rivers via Tech-talk
- ADVimba CPU usage Sandeep Kumar Malu - STFC UKRI via Tech-talk
Re: Generic EPICS IOCs Andrea michelotti via Tech-talk
Questions about creating a Model 3 Driver for stepper motor axis Paul-Elie GUILLOT via Tech-talk
<2024>
2025
<2024>
2025
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
