1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: re2c on Windows
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 21 Jan 2024 15:10:36 +0000
Hi Mark,
At NSLS-2, we are using re2c-1.0.3 to build the latest EPICS base (7.0.*). You can get it here: https://github.com/kgofron/windowsEPICS
That version of re2c is being used for auto-build of EPICS and other support modules (AreaDetector, etc.) on Windows at NSLS-2: https://github.com/NSLS-II/windows-epics-config
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Sunday, January 21, 2024 at 9:53
AM
To: [email protected] <[email protected]>
Subject: re2c on Windows
Folks,
I am trying to help someone build EPICS on Windows.  They need to have a copy of re2c.  I see that on my Windows machine I have re2c.exe which I put in C:\Program Files\re2c.  When I run that I see the version is 1.0.3.
C:\Windows\System32>re2c --version
re2c 1.0.3
I think I got that version from the Appveyor link pointed to by the Sequencer documentation: https://mdavidsaver.github.io/sequencer-mirror/Installation.html#re2c
On Windows things are not quite as smooth. The old re2c download page on sourceforge contains pre-built binaries for Windows systems, albeit only up to version 0.13.5. If this doesn’t work for you, there is EPICS-re2c, a version of re2c that has been wrapped as an EPICS module. There is also a Windows build of re2c-1.0.3 on Appveyor.
However, that artifact on Appveyor no longer exists, because they appear to only be kept for 1 month.
The re2c source version linked in the documentation that builds with the EPICS build system is here:
But that is re2c 0.16, so does not seem to be what was used to build 1.0.3.
Where are new EPICS Windows users supposed to find re2c?
Re: re2c on Windows Ralph Lange via Tech-talk
re2c on Windows Mark Rivers via Tech-talk
Prev: RE: re2c on Windows Engbretson, Mark S. via Tech-talk
Next: Re: re2c on Windows Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
