1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Subject: Re: RMP, REP garbage value
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: whitetiger1123 <holyeongbaeg at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 1 Feb 2024 09:47:10 -0600
Baeg,
Is the source code for the motor driver on github?
Kevin
On 2/1/24 00:41, whitetiger1123 via Tech-talk wrote:
Hi, all.
I have a question for a lot of epics officials and experts.
I made the controller with raspberry pie and plc for simple motor control.
However, if I looked at the epics css opi, I could see that the rmp or rep values were floating with strange garbage values.
Of course, I can force the value to be 0 by specifying the offset value, but when I turn off the controller,
the garbage values are floating again in rmp, rep and val, dval, and rval.
What can I do about this? Please advise me.
Sincerely,
Baeg
RMP, REP garbage value whitetiger1123 via Tech-talk
Prev: Re: Naming restriction in configure/RELEASE Hu, Yong via Tech-talk
Next: AW: motor model 3 with binary commands PiCo 33 piezo CN30 controller Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025
Prev: RMP, REP garbage value whitetiger1123 via Tech-talk
Next: Issue with Stream Device. Timeout only on Reconnect Maximilian Scharpey via Tech-talk
ANJ, 11 Sep 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
