Hi Abhishek, From the Linux Serial Console documentation (https: //docs. kernel. org/admin-guide/serial-console. html#: ~: text=The%20maximum%20baudrate%20is%20115200,on%20the%20kernel%20command%20line. &text=defines%20that%20opening%20%2Fdev%2Fconsole,or%20COM2)%20at%209600%20baud. )
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Abhishek,
Best,
Mrinal
On Feb 28, 2024, at 4:42 AM, Abhishek Mazumdar - STFC UKRI via Tech-talk < [email protected]> wrote:
Hello,
I am running an ioc for a device in linux which supports 125000 baud rate using UART communication.
The vendor of the device has provided python libraries through which I am able to communicate with the device without any issues.
The vendor's python libraries uses python serial package to communicate with the port /dev/ttyUSB1 (for example) using baud rate 125000.
But when I am using the baud rate 125000 in my ioc's st.cmd , I am not able to communicate with the device.
How to communicate with the device using 125000 baudrate using EPICs IOC ?
Abhishek Mazumdar
- Reg : How to use custom baud rate such as 125000 for ioc running on Linux Abhishek Mazumdar - STFC UKRI via Tech-talk
Re: pvAccess assert error Michael Davidsaver via Tech-talk
Re: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Mrinal Bera via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
