1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: archiver appliance quickstart installation
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "Rong Huang" <[email protected]>
Cc: [email protected]
Date: Thu, 29 Feb 2024 17:01:05 +0800 (GMT+08:00)
Hello Rong, According to the thread below, it seems that Archiver Appliance currently is not compatible with Tomcat 10, https: //epics. anl. gov/tech-talk/2023/msg01830. php You may want to try Tomcat 9 instead. Regards, Lin-----原始邮件----- 发件人: 
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hello Rong,
https://epics.anl.gov/tech-talk/2023/msg01830.php
Lin
-----原始邮件-----
发件人: "Rong Huang via Tech-talk" <[email protected]>
发送时间: 2024-02-29 05:28:56 (星期四)
收件人: [email protected]
主题: archiver appliance quickstart installation
Hello, Hope someone can help me on EPICS archiver appliance quickstart. I list what I did in the following, and please point out what I am missing or did wrong.   - computer system:  ubuntu 22. 04   - archiver appliance quickstart version:  archappl_v1. 1. 0
Hello,
  - computer system:  ubuntu 22.04
  - archiver appliance quickstart version:  archappl_v1.1.0
  1) epics base:   R7.0.8;  export EPICS_BASE=/home/archiver/epics/base
  2) openjdk-17-jdk; export JAVA_HOME=/usr/lib/jvm/java-17-openjdk-amd64
  3) download apache-tomcat-10.1.19. But later on disabled it by renaming the file /etc/systemd/system/tomcat.service to tomcat.service_NotUse, to avoid potential conflict with the tomcat loaded by quickstart.sh.
  4) installed mysql-server; also downloaded mysql-connector-java-8.3.0.jar, but is probably irrelevant since I can only copy this jar file into system tomcat which is disabled.
  5) download archappl_v1.1.0.tar.gz, apache-tomcat-10.1.19.tar.gz into one directory, unzip archappl_v1.1.0; run `./quickstart.sh apache-tomcat-10.1.19.tar.gz`
  The only website I can see is localhost:17665, the apache Tomcat/10.1.19 webpage. "HTTP 404" for localhost:17665/mgmt/ui/index.html, or any other pages.
Beginning part of the screen printout and a log file are also included in this email.
Thanks a lot,
Rong
 The printout up to first two "SEVERE" INFO:
SRCDIR=/home/archiver/epics/archive22
DATADIR=/home/archiver/epics/archive22
Using org.epics.archiverappliance.config.persistence.InMemoryPersistence as the persistence layer
Found an older quickstart_tomcat folder. Stopping any existing instances.
Using CATALINA_BASE:   /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
Using CATALINA_HOME:   /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
Using CATALINA_TMPDIR: /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/temp
Using JRE_HOME:        /usr/lib/jvm/java-17-openjdk-amd64
Using CLASSPATH:       /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/bin/bootstrap.jar:/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/bin/tomcat-juli.jar
Using CATALINA_OPTS:
Feb 28, 2024 2:46:43 PM org.apache.catalina.startup.Catalina stopServer
SEVERE: Could not contact [localhost:8005] (base port [8005] and offset [0]). Tomcat may not be running.
SEVERE: Error stopping Catalina
java.net.ConnectException: Connection refused
at java.base/sun.nio.ch.Net.connect0(Native Method)
at java.base/sun.nio.ch.Net.connect(Net.java:579)
at java.base/sun.nio.ch.Net.connect(Net.java:568)
at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:593)
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327)
at java.base/java.net.Socket.connect(Socket.java:633)
at java.base/java.net.Socket.connect(Socket.java:583)
at java.base/java.net.Socket.<init>(Socket.java:507)
at java.base/java.net.Socket.<init>(Socket.java:287)
at org.apache.catalina.startup.Catalina.stopServer(Catalina.java:653)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.apache.catalina.startup.Bootstrap.stopServer(Bootstrap.java:393)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:481)
Deleting an older quickstart_tomcat
total 4
drwxrwxr-x 9 archiver archiver 4096 Feb 28 14:47 apache-tomcat-10.1.19
Using 64 bit versions of libraries
Starting in the foreground...
28-Feb-2024 14:47:17.558 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name:   Apache Tomcat/10.1.19
28-Feb-2024 14:47:17.562 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built:          Feb 14 2024 19:36:50 UTC
28-Feb-2024 14:47:17.562 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 10.1.19.0
28-Feb-2024 14:47:17.562 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name:               Linux
28-Feb-2024 14:47:17.563 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version:            5.15.0-97-generic
28-Feb-2024 14:47:17.563 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture:          amd64
28-Feb-2024 14:47:17.563 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home:             /usr/lib/jvm/java-17-openjdk-amd64
28-Feb-2024 14:47:17.563 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version:           17.0.10+7-Ubuntu-122.04.1
28-Feb-2024 14:47:17.564 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor:            Private Build
28-Feb-2024 14:47:17.564 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE:         /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
28-Feb-2024 14:47:17.564 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME:         /home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
28-Feb-2024 14:47:17.627 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/conf/logging.properties
28-Feb-2024 14:47:17.628 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
28-Feb-2024 14:47:17.628 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx1G
28-Feb-2024 14:47:17.628 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -ea
28-Feb-2024 14:47:17.629 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
28-Feb-2024 14:47:17.629 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
28-Feb-2024 14:47:17.629 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
28-Feb-2024 14:47:17.630 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
28-Feb-2024 14:47:17.630 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
28-Feb-2024 14:47:17.630 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
28-Feb-2024 14:47:17.631 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
28-Feb-2024 14:47:17.631 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
28-Feb-2024 14:47:17.631 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
28-Feb-2024 14:47:17.632 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19
28-Feb-2024 14:47:17.632 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/temp
28-Feb-2024 14:47:18.258 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-17665"]
28-Feb-2024 14:47:18.290 INFO [main] org.apache.catalina.startup.Catalina.load Server initialization in [930] milliseconds
28-Feb-2024 14:47:18.322 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
28-Feb-2024 14:47:18.322 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/10.1.19]
28-Feb-2024 14:47:18.349 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [/home/archiver/epics/archive22/quickstart_tomcat/apache-tomcat-10.1.19/webapps/engine.war]
28-Feb-2024 14:47:21.313 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.28-Feb-2024 14:47:21.340 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
28-Feb-2024 14:47:21.364 SEVERE [main] org.apache.catalina.core.StandardContext.startInternal Context [/engine] startup failed due to previous errors
the beginning part inside localhost.2024-02-28.log file:
 28-Feb-2024 14:47:21.339 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener]
java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1017)
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2352)
at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:800)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1317)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:491)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:473)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:143)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4365)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4876)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:712)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:969)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1911)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:771)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:423)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1629)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:303)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:114)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:402)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:345)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:893)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:845)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:866)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:240)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:433)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:921)
at org.apache.catalina.startup.Catalina.start(Catalina.java:757)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:476)
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1353)
... 51 more
28-Feb-2024 14:47:21.340 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Skipped installing application listeners due to previous error(s)
28-Feb-2024 14:47:22.906 SEVERE [main] org.apache.catalina.core.StandardContext.listenerStart Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener]
Re: archiver appliance quickstart installation Rong Huang via Tech-talk
Prev: Re: pvAccess assert error Michael Davidsaver via Tech-talk
Next: Re: Reg : How to use custom baud rate such as 125000 for ioc running on Linux Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: archiver appliance quickstart installation Rong Huang via Tech-talk
Next: Re: archiver appliance quickstart installation Rong Huang via Tech-talk
