1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: communication issue
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Tran, Phi Dung" <[email protected]>
Date: Fri, 1 Mar 2024 19:40:12 +0000
Hi Alex,
Is your system firewall configured to not allow UDP traffic on port 5065 on the interfaces listed? You may also want to limit which interfaces are used by CAS with environment variables:
Best,
Jakub
From: Tech-talk <[email protected]> on behalf of Tran, Phi Dung via Tech-talk <[email protected]>
Sent: Friday, March 1, 2024 2:35 PM
To: [email protected] <[email protected]>
Subject: communication issue
I am getting this message output from st.cmd below.  Do you have any suggestions.
Thank you,
Alex
drvAsynIPPortConfigure ("OC_SP", "255.255.255.255:4004:4004 UDP", 0, 0, 0)
# Commands
drvAsynIPPortConfigure ("OC_CMD", "10.67.146.77:4004 UDP*", 0, 0, 0)
## Load record instances
dbLoadRecords("/epics/iocs/cs700/db/cs700.db", "P=cs700:,Q=CS,PORT=OC_SP,PORTCMD=OC_CMD")
dbLoadRecords("/usr/lib/epics/db/asynRecord.db","P=cs700:,R=CS:ASYN:SP,PORT=OC_SP,ADDR=0,OMAX=1000,IMAX=1000")
dbLoadRecords("/usr/lib/epics/db/asynRecord.db","P=cs700:,R=CS:ASYN:CMD,PORT=OC_CMD,ADDR=0,OMAX=1000,IMAX=1000")
iocInit()
Starting iocInit
## EPICS R7.0.5
## Rev. R7.0.5-dirty
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 37299,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
CAS: CA beacon send to 10.67.146.255:5065 error: Operation not permitted
## Start any sequence programs
CAS: CA beacon send to 10.67.144.255:5065 error: Operation not permitted
#seq snccs700,"user=ptran1"
CAS: CA beacon send to 10.67.145.255:5065 error: Operation not permitted
communication issue Tran, Phi Dung via Tech-talk
Prev: communication issue Tran, Phi Dung via Tech-talk
Next: CAEN V1742 support Brown, Garth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
